* | fstests/fsfseeko01: Fix for long == off_t | Sebastian Huber | 2015-04-08 | 1 | -4/+11 |
| | | | | Close #2317. | ||||
* | Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM | Sebastian Huber | 2014-12-16 | 1 | -2/+0 |
| | | | | This define was superfluous, undocumented and used inconsistently. | ||||
* | tests/fstests: Use <rtems/test.h> | Sebastian Huber | 2014-03-17 | 1 | -3/+6 |
* | fstests/fsfseeko01: Add test cases | Sebastian Huber | 2012-11-22 | 1 | -4/+26 |
* | misc fstests: Remove spaces at EOL | Joel Sherrill | 2012-10-01 | 1 | -1/+1 |
* | fstests/fsfseeko01: New test | Sebastian Huber | 2012-06-19 | 4 | -0/+117 |
