* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | dosfs: Fix fat_file_write() | Sebastian Huber | 2017-03-16 | 4 | -0/+150 |
Remove forced overwrite which leads to file data corruption. The logic to determine a forced overwrite was fundamentally broken. For simplity, disable this feature. Update #2622. |
