call to printk.
Updates #3170.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
Do not use our long file name entry count to optimize the file name
search. The Unicode comparison must be taken into account.
Update #2939.
It is all right in case the result uses the full destination buffer.
Without this fix the handling of a maximum 8.3 short file name is
broken.
Update #2928.
For a filename match the entry must match without anything remaining.
Close #2908.
Test handling of file names and directory names according to Microsofts
specification for the FAT file system. Tests for compatibility with a
genuine MS Windows FAT file system have been added.
Test handling of file names and directory names according to Microsofts specification
for the FAT file system. Tests for multibyte file names and directory names have been added.
specification for the FAT file system. So far tested only for the
default character set (code page 850).
