* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | config: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS | Sebastian Huber | 2019-12-19 | 1 | -1/+1 |
| | | | | | | | Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS into CONFIGURE_MAXIMUM_FILE_DESCRIPTORS. Update #3753. | ||||
* | tests: Avoid deprecated rtems_disk_io_initialize() | Sebastian Huber | 2018-08-07 | 1 | -3/+0 |
| | | | | Update #3358. | ||||
* | testsuite/fstests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -19/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | dosfs: Support a cluster size of 64KiB | Sebastian Huber | 2017-09-06 | 1 | -0/+28 |
| | | | | Close #3003. | ||||
* | tests: Use floating point task | Sebastian Huber | 2017-07-18 | 1 | -0/+2 |
| | | | | | | | These tests directly or indirectly use fprintf(), etc. which may use the floating point unit. Update #3076. | ||||
* | Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM | Sebastian Huber | 2014-12-16 | 1 | -2/+0 |
| | | | | This define was superfluous, undocumented and used inconsistently. | ||||
* | testsuites: Remove BSP_SMALL_MEMORY | Joel Sherrill | 2014-05-06 | 1 | -10/+4 |
* | fsdosfsformat01: Honor BSP_SMALL_MEMORY | Joel Sherrill | 2014-04-22 | 1 | -4/+10 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | tests/fstests: Use <rtems/test.h> | Sebastian Huber | 2014-03-17 | 1 | -3/+6 |
* | fsdosfsformat01.doc: Add contents | Cynthia Rempel | 2014-01-07 | 1 | -4/+18 |
* | fsdosfsformat01: Add test for re-mount of a filesystem | Ralf Kirchner | 2013-10-18 | 1 | -0/+11 |
* | dosfs: Bugfix for disks of for example 100MB size | Ralf Kirchner | 2012-12-13 | 1 | -11/+60 |
* | fstests/fsdosfsformat01: New test | Ralf Kirchner | 2012-12-05 | 4 | -0/+477 |
