* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | libio: Use FIFO for iop free list | Sebastian Huber | 2017-09-15 | 1 | -4/+27 |
| | | | | Update #3136. | ||||
* | libio: Add hold/drop iop reference | Sebastian Huber | 2017-09-15 | 4 | -0/+558 |
Check iop reference count in close() and return -1 with errno set to EBUSY in case the file descriptor is still in use. Update #3132. |
