path: root/testsuites/fstests/fsbdpart01 (follow)
* config: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORSSebastian Huber2019-12-191-1/+1
| | | | | | | Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS into CONFIGURE_MAXIMUM_FILE_DESCRIPTORS. Update #3753.
* testsuite/fstests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-20/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* tests: Use floating point taskSebastian Huber2017-07-181-0/+2
| | | | | | | These tests directly or indirectly use fprintf(), etc. which may use the floating point unit. Update #3076.
* Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEMSebastian Huber2014-12-161-2/+0
| | | | This define was superfluous, undocumented and used inconsistently.
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* tests/fstests: Use <rtems/test.h>Sebastian Huber2014-03-171-3/+6
* fsbdpart01.doc: Add contentsCynthia Rempel2014-01-071-4/+21
* testsuites: Fix warningsSebastian Huber2013-04-111-0/+3
* libblock: Do resource allocation in one placeSebastian Huber2013-02-211-16/+0
| | | | | | | All resource allocations take place in rtems_bdbuf_init() now. After rtems_bdbuf_init() no fatal errors can happen due to configuration errors or resource limits. This makes it easier to detect configuration errors for users.
* libblock: Use rtems_blkdev_create_partition()Sebastian Huber2012-12-211-2/+26
| | | | | Use rtems_blkdev_create_partition() instead of rtems_disk_create_log() to avoid problems with the huge IMFS_GENERIC_DEVICE_MAJOR_NUMBER.
* libblock: Remove const qualifier from bdbuf APISebastian Huber2012-05-311-1/+1
| | | | This allows addtion of per disk statistics for example.
* fstests/fsbdpart01: New testSebastian Huber2012-03-134-0/+279
