path: root/testsuites/fstests/ChangeLog (follow)
* 2011-10-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-261-0/+6
| | | | | | * Makefile.am: Fix DIST_SUBDIRS. Reformat. Add support/fstest.h.
* 2011-10-18 Jennifer Averett <Jennifer.Averett@OARcorp.comJennifer Averett2011-10-181-0/+5
| | | | | * mrfs_support/fs_support.c: Resolved name conflict that was causing a compiler error.
* 2011-09-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-09-301-0/+4
| | | | * fsrdwr/init.c: Use %zd to print size_t.
* 2011-09-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-09-301-0/+8
| | | | | | | | * fserror/test.c, fslink/test.c, fspatheval/test.c, fspermission/test.c, fsrdwr/init.c, fssymlink/test.c, fstime/test.c, support/fstest_support.c, support/ramdisk_support.c: Explicitly include "pmacros.h". * support/fstest.h: Don't include "pmacros.h".
* 2011-09-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-09-071-0/+2
| | | | | * imfs_support/fs_supprot.h, support/fstest.h, support/ramdisk_support.h: Don't include config.h.
* 2011-09-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-09-071-0/+4
| | | | | | | * fserror/test.c, fslink/test.c, fspatheval/test.c, fspermission/test.c, fsrdwr/init.c, fssymlink/test.c, fstime/test.c, support/fstest_support.c, support/ramdisk_support.c: Add config-header support.
* 2011-09-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-09-071-0/+1
| | | | * support/fstest.h: Include "pmacros.h".
* 2011-09-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-09-071-0/+16
| | | | | | | | | | | | | | | | * fserror/fserror.doc, fserror/test.c, fslink/fslink.doc, fslink/test.c, fspatheval/patheval.doc, fspatheval/test.c, fspermission/fspermission.doc, fspermission/test.c, fsrdwr/fsrdwr.doc, fsrdwr/init.c, fssymlink/fssymlink.doc, fssymlink/test.c, fstime/fstime.doc, fstime/test.c, imfs_support/fs_config.h, imfs_support/fs_support.c, imfs_support/fs_supprot.h, mdosfs_support/fs_config.h, mdosfs_support/fs_support.c, mimfs_support/fs_config.h, mimfs_support/fs_support.c, mrfs_support/fs_config.h, mrfs_support/fs_support.c, support/fstest.h, support/fstest_support.c, support/fstest_support.h, support/ramdisk_support.c, support/ramdisk_support.h: Fix CVS-Ids.
* 2011-08-02 Xiang Cui <medivhc@gmail.com>Joel Sherrill2011-08-021-0/+10
| | | | | | | | | | * configure.ac, fserror/test.c, fslink/test.c, fspermission/test.c, fsrdwr/init.c, fssymlink/test.c, fstime/test.c, mdosfs_support/fs_config.h, mdosfs_support/fs_support.c, mimfs_support/fs_support.c, mrfs_support/fs_config.h, support/fstest.h, support/fstest_support.c, support/ramdisk_support.c, support/ramdisk_support.h: Perform first phase of clean up.
* 2011-08-01 Xiang Cui <medivhc@gmail.com>Joel Sherrill2011-08-011-0/+34
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * imfs_fslink/Makefile.am, imfs_fssymlink/Makefile.am, mimfs_fslink/Makefile.am, mimfs_fssymlink/Makefile.am, mrfs_fslink/Makefile.am, mrfs_fssymlink/Makefile.am, mrfs_support/fs_config.h: Correcting from previous commit of incorrect tarball. * fserror/fserror.doc, fserror/test.c, fspatheval/patheval.doc, fspatheval/test.c, fspermission/fspermission.doc, fspermission/test.c, fsrdwr/fsrdwr.doc, fsrdwr/init.c, fstime/fstime.doc, fstime/test.c, imfs_fserror/.cvsignore, imfs_fserror/Makefile.am, imfs_fslink/.cvsignore, imfs_fspatheval/.cvsignore, imfs_fspatheval/Makefile.am, imfs_fspermission/.cvsignore, imfs_fspermission/Makefile.am, imfs_fsrdwr/.cvsignore, imfs_fsrdwr/Makefile.am, imfs_fssymlink/.cvsignore, imfs_fstime/.cvsignore, imfs_fstime/Makefile.am, imfs_support/fs_supprot.h, mdosfs_fserror/.cvsignore, mdosfs_fserror/Makefile.am, mdosfs_fspatheval/.cvsignore, mdosfs_fspatheval/Makefile.am, mdosfs_fsrdwr/.cvsignore, mdosfs_fsrdwr/Makefile.am, mdosfs_fstime/.cvsignore, mdosfs_fstime/Makefile.am, mimfs_fserror/.cvsignore, mimfs_fserror/Makefile.am, mimfs_fslink/.cvsignore, mimfs_fspatheval/.cvsignore, mimfs_fspatheval/Makefile.am, mimfs_fspermission/.cvsignore, mimfs_fspermission/Makefile.am, mimfs_fsrdwr/.cvsignore, mimfs_fsrdwr/Makefile.am, mimfs_fssymlink/.cvsignore, mimfs_fstime/.cvsignore, mimfs_fstime/Makefile.am, mrfs_fserror/.cvsignore, mrfs_fserror/Makefile.am, mrfs_fslink/.cvsignore, mrfs_fspatheval/.cvsignore, mrfs_fspatheval/Makefile.am, mrfs_fspermission/.cvsignore, mrfs_fspermission/Makefile.am, mrfs_fsrdwr/.cvsignore, mrfs_fsrdwr/Makefile.am, mrfs_fssymlink/.cvsignore, mrfs_fstime/.cvsignore, mrfs_fstime/Makefile.am: New files.
* 2011-08-01 Xiang Cui <medivhc@gmail.com>Joel Sherrill2011-08-011-0/+94
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, configure.ac, fslink/fslink.doc, fslink/test.c, fssymlink/test.c, imfs_fslink/Makefile.am, imfs_fssymlink/Makefile.am, imfs_support/fs_config.h, imfs_support/fs_support.c, mdosfs_support/fs_config.h, mdosfs_support/fs_support.c, mimfs_fslink/Makefile.am, mimfs_fssymlink/Makefile.am, mimfs_support/fs_config.h, mimfs_support/fs_support.c, mrfs_fslink/Makefile.am, mrfs_fssymlink/Makefile.am, mrfs_support/fs_config.h, mrfs_support/fs_support.c, support/fstest.h, support/fstest_support.c, support/fstest_support.h, support/ramdisk_support.c, support/ramdisk_support.h: Submit correct tarball of current work. * fs01/init.c, fsfchx/fsfchx.doc, fsfchx/init.c, fsfile01/fsfile01.doc, fsfile01/test.c, fsfile01/test_cat.c, fsfile01/test_extend.c, fsfile01/test_write.c, fsfile02/fsfile02.doc, fsfile02/init.c, fsfstest/fs-test.c, fsfstest/fsfstest.doc, fsimfs01/fsimfs01.doc, fsimfs01/init.c, fsimfs02/fsimfs02.doc, fsimfs02/init.c, fsmkdir/fsmkdir.doc, fsmkdir/test.c, fsopen/fsopen.doc, fsopen/test.c, fsrdwrv/fsrdwrv.doc, fsrdwrv/test.c, fsreaddir/fsreaddir.doc, fsreaddir/test.c, fsrename/fsrename.doc, fsrename/test.c, fsrmdir/test.c, fsrwfile/fsrwfile.doc, fsrwfile/init.c, fsstat/fsstat.doc, fsstat/test.c, fstruncate/fstruncate.doc, fstruncate/test.c, imfs_fs01/.cvsignore, imfs_fs01/Makefile.am, imfs_fs01/imfs_fs01.scn, imfs_fsfchx/.cvsignore, imfs_fsfchx/Makefile.am, imfs_fsfile01/.cvsignore, imfs_fsfile01/Makefile.am, imfs_fsfile02/.cvsignore, imfs_fsfile02/Makefile.am, imfs_fsfstest/.cvsignore, imfs_fsfstest/Makefile.am, imfs_fsimfs01/.cvsignore, imfs_fsimfs01/Makefile.am, imfs_fsimfs02/.cvsignore, imfs_fsimfs02/Makefile.am, imfs_fslink/.cvsignore, imfs_fsmkdir/.cvsignore, imfs_fsmkdir/Makefile.am, imfs_fsopen/.cvsignore, imfs_fsopen/Makefile.am, imfs_fsrdwrv/.cvsignore, imfs_fsrdwrv/Makefile.am, imfs_fsreaddir/.cvsignore, imfs_fsreaddir/Makefile.am, imfs_fsrename/.cvsignore, imfs_fsrename/Makefile.am, imfs_fsrmdir/.cvsignore, imfs_fsrmdir/Makefile.am, imfs_fsrwfile/.cvsignore, imfs_fsrwfile/Makefile.am, imfs_fsstat/.cvsignore, imfs_fsstat/Makefile.am, imfs_fssymlink/.cvsignore, imfs_fstruncate/.cvsignore, imfs_fstruncate/Makefile.am, mdosfs_fsfchx/.cvsignore, mdosfs_fsfchx/Makefile.am, mdosfs_fsfile01/.cvsignore, mdosfs_fsfile01/Makefile.am, mdosfs_fsfile02/.cvsignore, mdosfs_fsfile02/Makefile.am, mdosfs_fsfstest/.cvsignore, mdosfs_fsfstest/Makefile.am, mdosfs_fsimfs01/.cvsignore, mdosfs_fsimfs01/Makefile.am, mdosfs_fsimfs02/.cvsignore, mdosfs_fsimfs02/Makefile.am, mdosfs_fslink/.cvsignore, mdosfs_fslink/Makefile.am, mdosfs_fsmkdir/.cvsignore, mdosfs_fsmkdir/Makefile.am, mdosfs_fsopen/.cvsignore, mdosfs_fsopen/Makefile.am, mdosfs_fsrdwrv/.cvsignore, mdosfs_fsrdwrv/Makefile.am, mdosfs_fsreaddir/.cvsignore, mdosfs_fsreaddir/Makefile.am, mdosfs_fsrename/.cvsignore, mdosfs_fsrename/Makefile.am, mdosfs_fsrmdir/.cvsignore, mdosfs_fsrmdir/Makefile.am, mdosfs_fsrwfile/.cvsignore, mdosfs_fsrwfile/Makefile.am, mdosfs_fsstat/.cvsignore, mdosfs_fsstat/Makefile.am, mdosfs_fssymlink/.cvsignore, mdosfs_fssymlink/Makefile.am, mdosfs_fstruncate/.cvsignore, mdosfs_fstruncate/Makefile.am, mimfs_fs01/.cvsignore, mimfs_fs01/Makefile.am, mimfs_fs01/mimfs_fs01.scn, mimfs_fsfchx/.cvsignore, mimfs_fsfchx/Makefile.am, mimfs_fsfile01/.cvsignore, mimfs_fsfile01/Makefile.am, mimfs_fsfile02/.cvsignore, mimfs_fsfile02/Makefile.am, mimfs_fsfstest/.cvsignore, mimfs_fsfstest/Makefile.am, mimfs_fsimfs01/.cvsignore, mimfs_fsimfs01/Makefile.am, mimfs_fsimfs02/.cvsignore, mimfs_fsimfs02/Makefile.am, mimfs_fslink/.cvsignore, mimfs_fsmkdir/.cvsignore, mimfs_fsmkdir/Makefile.am, mimfs_fsopen/.cvsignore, mimfs_fsopen/Makefile.am, mimfs_fsrdwrv/.cvsignore, mimfs_fsrdwrv/Makefile.am, mimfs_fsreaddir/.cvsignore, mimfs_fsreaddir/Makefile.am, mimfs_fsrename/.cvsignore, mimfs_fsrename/Makefile.am, mimfs_fsrmdir/.cvsignore, mimfs_fsrmdir/Makefile.am, mimfs_fsrwfile/.cvsignore, mimfs_fsrwfile/Makefile.am, mimfs_fsstat/.cvsignore, mimfs_fsstat/Makefile.am, mimfs_fssymlink/.cvsignore, mimfs_fstruncate/.cvsignore, mimfs_fstruncate/Makefile.am, mrfs_fsfchx/.cvsignore, mrfs_fsfchx/Makefile.am, mrfs_fsfile01/.cvsignore, mrfs_fsfile01/Makefile.am, mrfs_fsfile02/.cvsignore, mrfs_fsfile02/Makefile.am, mrfs_fsfstest/.cvsignore, mrfs_fsfstest/Makefile.am, mrfs_fsimfs01/.cvsignore, mrfs_fsimfs01/Makefile.am, mrfs_fsimfs02/.cvsignore, mrfs_fsimfs02/Makefile.am, mrfs_fslink/.cvsignore, mrfs_fsmkdir/.cvsignore, mrfs_fsmkdir/Makefile.am, mrfs_fsopen/.cvsignore, mrfs_fsopen/Makefile.am, mrfs_fsrdwrv/.cvsignore, mrfs_fsrdwrv/Makefile.am, mrfs_fsreaddir/.cvsignore, mrfs_fsreaddir/Makefile.am, mrfs_fsrename/.cvsignore, mrfs_fsrename/Makefile.am, mrfs_fsrmdir/.cvsignore, mrfs_fsrmdir/Makefile.am, mrfs_fsrwfile/.cvsignore, mrfs_fsrwfile/Makefile.am, mrfs_fsstat/.cvsignore, mrfs_fsstat/Makefile.am, mrfs_fssymlink/.cvsignore, mrfs_fstruncate/.cvsignore, mrfs_fstruncate/Makefile.am: Removed.
* 2011-08-01 Xiang Cui <medivhc@gmail.com>Joel Sherrill2011-08-011-0/+92
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, configure.ac, imfs_support/fs_config.h, imfs_support/fs_support.c, mimfs_support/fs_config.h, mimfs_support/fs_support.c: Add initial version of new filesystem tests. There are multiple failures which need to be addressed by the community. * fsfchx/fsfchx.doc, fsfchx/init.c, fsfile01/fsfile01.doc, fsfile01/test.c, fsfile01/test_cat.c, fsfile01/test_extend.c, fsfile01/test_write.c, fsfile02/fsfile02.doc, fsfile02/init.c, fsfstest/fs-test.c, fsfstest/fsfstest.doc, fsimfs01/fsimfs01.doc, fsimfs01/init.c, fsimfs02/fsimfs02.doc, fsimfs02/init.c, fslink/fslink.doc, fslink/test.c, fsmkdir/fsmkdir.doc, fsmkdir/test.c, fsopen/fsopen.doc, fsopen/test.c, fsrdwrv/fsrdwrv.doc, fsrdwrv/test.c, fsreaddir/fsreaddir.doc, fsreaddir/test.c, fsrename/fsrename.doc, fsrename/test.c, fsrmdir/test.c, fsrwfile/fsrwfile.doc, fsrwfile/init.c, fsstat/fsstat.doc, fsstat/test.c, fssymlink/fssymlink.doc, fssymlink/test.c, fstruncate/fstruncate.doc, fstruncate/test.c, imfs_fsfchx/.cvsignore, imfs_fsfchx/Makefile.am, imfs_fsfile01/.cvsignore, imfs_fsfile01/Makefile.am, imfs_fsfile02/.cvsignore, imfs_fsfile02/Makefile.am, imfs_fsfstest/.cvsignore, imfs_fsfstest/Makefile.am, imfs_fsimfs01/.cvsignore, imfs_fsimfs01/Makefile.am, imfs_fsimfs02/.cvsignore, imfs_fsimfs02/Makefile.am, imfs_fslink/.cvsignore, imfs_fslink/Makefile.am, imfs_fsmkdir/.cvsignore, imfs_fsmkdir/Makefile.am, imfs_fsopen/.cvsignore, imfs_fsopen/Makefile.am, imfs_fsrdwrv/.cvsignore, imfs_fsrdwrv/Makefile.am, imfs_fsreaddir/.cvsignore, imfs_fsreaddir/Makefile.am, imfs_fsrename/.cvsignore, imfs_fsrename/Makefile.am, imfs_fsrmdir/.cvsignore, imfs_fsrmdir/Makefile.am, imfs_fsrwfile/.cvsignore, imfs_fsrwfile/Makefile.am, imfs_fsstat/.cvsignore, imfs_fsstat/Makefile.am, imfs_fssymlink/.cvsignore, imfs_fssymlink/Makefile.am, imfs_fstruncate/.cvsignore, imfs_fstruncate/Makefile.am, mdosfs_fsfchx/.cvsignore, mdosfs_fsfchx/Makefile.am, mdosfs_fsfile01/.cvsignore, mdosfs_fsfile01/Makefile.am, mdosfs_fsfile02/.cvsignore, mdosfs_fsfile02/Makefile.am, mdosfs_fsfstest/.cvsignore, mdosfs_fsfstest/Makefile.am, mdosfs_fsimfs01/.cvsignore, mdosfs_fsimfs01/Makefile.am, mdosfs_fsimfs02/.cvsignore, mdosfs_fsimfs02/Makefile.am, mdosfs_fslink/.cvsignore, mdosfs_fslink/Makefile.am, mdosfs_fsmkdir/.cvsignore, mdosfs_fsmkdir/Makefile.am, mdosfs_fsopen/.cvsignore, mdosfs_fsopen/Makefile.am, mdosfs_fsrdwrv/.cvsignore, mdosfs_fsrdwrv/Makefile.am, mdosfs_fsreaddir/.cvsignore, mdosfs_fsreaddir/Makefile.am, mdosfs_fsrename/.cvsignore, mdosfs_fsrename/Makefile.am, mdosfs_fsrmdir/.cvsignore, mdosfs_fsrmdir/Makefile.am, mdosfs_fsrwfile/.cvsignore, mdosfs_fsrwfile/Makefile.am, mdosfs_fsstat/.cvsignore, mdosfs_fsstat/Makefile.am, mdosfs_fssymlink/.cvsignore, mdosfs_fssymlink/Makefile.am, mdosfs_fstruncate/.cvsignore, mdosfs_fstruncate/Makefile.am, mdosfs_support/fs_config.h, mdosfs_support/fs_support.c, mimfs_fsfchx/.cvsignore, mimfs_fsfchx/Makefile.am, mimfs_fsfile01/.cvsignore, mimfs_fsfile01/Makefile.am, mimfs_fsfile02/.cvsignore, mimfs_fsfile02/Makefile.am, mimfs_fsfstest/.cvsignore, mimfs_fsfstest/Makefile.am, mimfs_fsimfs01/.cvsignore, mimfs_fsimfs01/Makefile.am, mimfs_fsimfs02/.cvsignore, mimfs_fsimfs02/Makefile.am, mimfs_fslink/.cvsignore, mimfs_fslink/Makefile.am, mimfs_fsmkdir/.cvsignore, mimfs_fsmkdir/Makefile.am, mimfs_fsopen/.cvsignore, mimfs_fsopen/Makefile.am, mimfs_fsrdwrv/.cvsignore, mimfs_fsrdwrv/Makefile.am, mimfs_fsreaddir/.cvsignore, mimfs_fsreaddir/Makefile.am, mimfs_fsrename/.cvsignore, mimfs_fsrename/Makefile.am, mimfs_fsrmdir/.cvsignore, mimfs_fsrmdir/Makefile.am, mimfs_fsrwfile/.cvsignore, mimfs_fsrwfile/Makefile.am, mimfs_fsstat/.cvsignore, mimfs_fsstat/Makefile.am, mimfs_fssymlink/.cvsignore, mimfs_fssymlink/Makefile.am, mimfs_fstruncate/.cvsignore, mimfs_fstruncate/Makefile.am, mrfs_fsfchx/.cvsignore, mrfs_fsfchx/Makefile.am, mrfs_fsfile01/.cvsignore, mrfs_fsfile01/Makefile.am, mrfs_fsfile02/.cvsignore, mrfs_fsfile02/Makefile.am, mrfs_fsfstest/.cvsignore, mrfs_fsfstest/Makefile.am, mrfs_fsimfs01/.cvsignore, mrfs_fsimfs01/Makefile.am, mrfs_fsimfs02/.cvsignore, mrfs_fsimfs02/Makefile.am, mrfs_fslink/.cvsignore, mrfs_fslink/Makefile.am, mrfs_fsmkdir/.cvsignore, mrfs_fsmkdir/Makefile.am, mrfs_fsopen/.cvsignore, mrfs_fsopen/Makefile.am, mrfs_fsrdwrv/.cvsignore, mrfs_fsrdwrv/Makefile.am, mrfs_fsreaddir/.cvsignore, mrfs_fsreaddir/Makefile.am, mrfs_fsrename/.cvsignore, mrfs_fsrename/Makefile.am, mrfs_fsrmdir/.cvsignore, mrfs_fsrmdir/Makefile.am, mrfs_fsrwfile/.cvsignore, mrfs_fsrwfile/Makefile.am, mrfs_fsstat/.cvsignore, mrfs_fsstat/Makefile.am, mrfs_fssymlink/.cvsignore, mrfs_fssymlink/Makefile.am, mrfs_fstruncate/.cvsignore, mrfs_fstruncate/Makefile.am, mrfs_support/fs_config.h, mrfs_support/fs_support.c, support/fstest.h, support/fstest_support.c, support/fstest_support.h, support/ramdisk_support.c, support/ramdisk_support.h: New files.
* 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-06-201-0/+6
| | | | | | * Makefile.am: Remove EXTRA_DIST. * fs01/fs91.doc: Remove (Empty, unused). * mimfs_fs01/Makefile.am: Use mimfs_support/fs_config.h.
* 2011-04-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-04-201-0/+10
Add initial test to File System Test Suite. * .cvsignore, ChangeLog, Makefile.am, configure.ac, fs01/fs91.doc, fs01/init.c, imfs_fs01/.cvsignore, imfs_fs01/Makefile.am, imfs_fs01/imfs_fs01.scn, imfs_support/fs_config.h, imfs_support/fs_support.c, mimfs_fs01/.cvsignore, mimfs_fs01/Makefile.am, mimfs_fs01/mimfs_fs01.scn, mimfs_support/fs_config.h, mimfs_support/fs_support.c: New files.
