upgrade to that version.
Close #3387.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This solves a build dependency issue, e.g. building tests before
librtemsbsp.a exists.
Close #3079.
Update #2958.
We always build a C++ compiler and building with C++ does not effect
RTEMS or the runtime. This patch always enabled the support. There is
no need to manually enable it any more.
You can disable C++ with '--disable-cxx'.
If an architecture does not have a C++ compiler support is automatically
disabled.
The Rhealstone benchmarks six operations that are critical components
of a real-time system. It allows for an objective analysis to be
performed, and allows for comparisons between systems.
See rhealstone/README for more information.
for details.
* configure.ac, support/include/test_support.h:
* support/src/locked_print.c: New file.
* configure.ac: Add fstests.
* configure.ac: Add initial small set of POSIX Timing Tests.
* configure.ac: Remove itron.
* configure.ac: Some POSIX tests exercise functionality which is
enabled when the POSIX threading is disabled. So build this suite all
the time and let the psxtests select the specific tests to build.
* configure.ac: Remove RTEMS_ENABLE_BARE,
BARE_CPU_CFLAGS, BARE_CPU_MODEL.
* configure.ac: Remove AMPOLISH3 (Unused).
* configure.ac: Fix config-variables of conditionally built subdirs.
* configure.ac: Apply RTEMS_CHECK_CPUOPTS.
* configure.ac: Add 2nd arg to RTEMS_TOP.
* configure.ac: AC_CONFIG_SRCDIR([PROBLEMS]).
* aclocal/check-custom-bsp.m4: Sync with c/src/aclocal.
* aclocal/project-root.m4: Remove obsolete comments.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT.
* aclocal/rtems-top.m4: Rework.
* configure.ac: Remove subdir tools.
* configure.ac: Reflect having moved to testsuites/.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac:Remove RTEMS_CHECK_CPU.
* aclocal/check-cpu.m4: Remove.
* aclocal/check-cxx.m4, aclocal/check-itron.m4,
aclocal/check-multiprocessing.m4, aclocal/check-networking.m4,
aclocal/check-posix.m4: AC_REQUIRE RTEMS_CANONICAL_TARGET_CPU instead of
RTEMS_CHECK_CPU.
* aclocal/enable-tests.m4: Change to support
--enable-tests=no|yes|samples, default is samples.
* configure.in: Remove.
