* configure.ac: AC_CONFIG_SRCDIR([PROBLEMS]).
* aclocal/check-custom-bsp.m4: Sync with c/src/aclocal.
* aclocal/project-root.m4: Remove obsolete comments.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT.
* aclocal/rtems-top.m4: Rework.
* configure.ac: Remove subdir tools.
* configure.ac: Reflect having moved to testsuites/.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac:Remove RTEMS_CHECK_CPU.
* aclocal/check-cpu.m4: Remove.
* aclocal/check-cxx.m4, aclocal/check-itron.m4,
aclocal/check-multiprocessing.m4, aclocal/check-networking.m4,
aclocal/check-posix.m4: AC_REQUIRE RTEMS_CANONICAL_TARGET_CPU instead of
RTEMS_CHECK_CPU.
* aclocal/enable-tests.m4: Change to support
--enable-tests=no|yes|samples, default is samples.
* configure.in: Remove.
