2011-06-28 | 2011-06-28 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* configure.ac, support/include/test_support.h: * support/src/locked_print.c: New file. | |||||
2011-04-20 | 2011-04-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* configure.ac: Add fstests. | |||||
2011-02-02 | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* configure.ac: Require autoconf-2.68, automake-1.11.1. | |||||
2010-12-06 | 2010-12-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* configure.ac: Add initial small set of POSIX Timing Tests. | |||||
2010-06-17 | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -7/+0 | |
* configure.ac: Remove itron. | |||||
2009-09-13 | 2009-09-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -4/+1 | |
* configure.ac: Some POSIX tests exercise functionality which is enabled when the POSIX threading is disabled. So build this suite all the time and let the psxtests select the specific tests to build. | |||||
2006-12-02 | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* configure.ac: New BUG-REPORT address. | |||||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* configure.ac: Require autoconf-2.60. Require automake-1.10. | |||||
2005-11-22 | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -3/+0 | |
* configure.ac: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL. | |||||
2005-11-13 | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -4/+0 | |
* configure.ac: Remove AMPOLISH3 (Unused). | |||||
2005-11-09 | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -4/+4 | |
* configure.ac: Fix config-variables of conditionally built subdirs. | |||||
2005-11-09 | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -12/+9 | |
* configure.ac: Apply RTEMS_CHECK_CPUOPTS. | |||||
2005-11-09 | Add AMPOLISH3. Remove support/. | Ralf Corsepius | 1 | -1/+4 | |
2005-11-07 | Sync POSIX and ITRON magic with cpukit. | Ralf Corsepius | 1 | -3/+3 | |
2004-09-24 | Fix typo in previous change. | Ralf Corsepius | 1 | -1/+1 | |
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* configure.ac: Require automake > 1.9. | |||||
2004-03-25 | 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* configure.ac: Add 2nd arg to RTEMS_TOP. | |||||
2004-02-19 | 2004-02-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* configure.ac: AC_CONFIG_SRCDIR([PROBLEMS]). * aclocal/check-custom-bsp.m4: Sync with c/src/aclocal. * aclocal/project-root.m4: Remove obsolete comments. * aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT. * aclocal/rtems-top.m4: Rework. | |||||
2004-02-14 | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+0 | |
* configure.ac: Remove subdir tools. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -2/+2 | |
* configure.ac: Require automake >= 1.8, autoconf >= 2.59. | |||||
2003-11-10 | 2003-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* configure.ac: Reflect having moved to testsuites/. | |||||
2003-10-22 | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+0 | |
* configure.ac: Remove RTEMS_CANONICAL_HOST. | |||||
2003-10-02 | 2003-10-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+0 | |
* configure.ac:Remove RTEMS_CHECK_CPU. * aclocal/check-cpu.m4: Remove. * aclocal/check-cxx.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-networking.m4, aclocal/check-posix.m4: AC_REQUIRE RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU. | |||||
2003-08-22 | 2003-08-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -4/+9 | |
* aclocal/enable-tests.m4: Change to support --enable-tests=no|yes|samples, default is samples. * configure.ac: Reflect changes above. | |||||
2003-08-11 | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||||
2003-03-11 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -1/+0 | |
2003-02-11 | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | |||||
* configure.ac: AC_PREREQ(2.57). | |||||
2002-04-16 | 2002-04-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+0 | |
* configure.ac: Remove ENABLE_GCC28. | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -2/+2 | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2001-10-12 | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+64 | |
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. |
