* | testsuite/benchmarks: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -20/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Use printf() instead of fprintf() | Sebastian Huber | 2017-11-02 | 1 | -0/+1 |
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | dhrystone/dhry_1.c: Move assignment to before start of timer | Joel Sherrill | 2017-04-26 | 1 | -5/+5 |
* | dhrystone/dhry_1.c: Fix may be used uninitialized warning | Joel Sherrill | 2017-04-23 | 1 | -0/+5 |
* | dhrystone: Fix warnings | Sebastian Huber | 2017-04-05 | 1 | -2/+4 |
| | | | | Close #2977. | ||||
* | benchmarks/dhrystone: Port to RTEMS | Sebastian Huber | 2017-03-29 | 7 | -33/+128 |
| | | | | Update #2958. | ||||
* | benchmarks/dhrystone: Import | Sebastian Huber | 2017-03-29 | 6 | -0/+1596 |
| | | | | | | | | Import dhrystone sources from: http://www.netlib.org/benchmark/dhry-c Update #2958. | ||||
* | benchmarks: Add benchmark templates | Sebastian Huber | 2017-03-29 | 4 | -0/+78 |
Update #2958. |
