Close #3250.
Close #4081.
This is an example test using the RTEMS Test Framework. It tests also
the framework itself.
Add T_FILE_NAME command line define to get rid of the full file path.
This is important to reduce the read-only data of test files and make
them build system independent.
Update #3199.
One reason to move the test support into a dedicated library are the
standard output __wrap_*() functions. They may conflict with
application level wrappers.
Update #3199.
Remove use of TMPINSTALL_FILES.
Update #3254.
Leave the parallel support so each test group builds in parallel.
Update #3382
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
- Remove the macro defines and the need for tmacro.h by remapping the
symbols using ld's wrap option.
- Remove FLUSH_OUTPUT, it was empty.
- Move rtems_test_exit to libmisc/testsupport as a function.
Update #3199.
Fix excluding `math` when there is a test `mathl`. The shell test
used fails in this case. This patch's approach is much simpler.
The include file handling was broken.
Add a test configuration data README.
Closes #2981.
errors.
- Add a top level test configuration file for test states that are common
to all BSPs. This saves adding a test configuration (tcfg) file for
every BSP.
- Add the test states 'user-input' and 'benchmark'. This
lets 'rtems-test' stop the test rather than waiting for a timeout or
letting a benchmark run without the user asking for it to run.
- Implement rtems-test-check in Python to make it faster. The shell script
had grown to a point it was noticably slowing the build down.
- Fix the configure.ac and Makefile.am files for a number of the
test directories. The files are difficiult to keep in sync with the
number of tests and mistakes can happen such as tests being left
out of the build. The test fsrofs01 is an example. Also a there was
a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be
used.
- Fix the test fsrofs01 so it compiles.
Closes #2963.
BSD sed does not support '\t' and treated '[ \t]' as 3 characters. This patch
uses a standard method of supporting blank spaces.
Change the testsuite configuration files to hold state information about
a test. The states are:
exclude - Do not build the test
expected-fail - The test is expected to fail
indeterminate - The test may pass or may fail
A message is printed just after the test's BEGIN message to indicate
there is a special state for the test. No state message means the test
is expected to pass.
This support requires tests are correctly written to the use standard
support to begin and end a test.
BSPs for simulators which do not include a clock tick interrupt source
are incapable of running some tests successfully. This is a common
characteristic of some BSPs and a fixed set of tests. There is no point
in duplicating this list of tests in those BSPs test configuration.
Read testsuites/testdata/require-tick-isr.tcfg for details.
Provide a file per BSP to list tests that do not build for a BSP. This change
removes the BSP_SMALL_MEMORY hack from the code. That hack was a
mistake.
Provide configuration files for each BSP with tests that cannot build.
* automake/compile.am: Remove clean-local:.
Use CLEANFILES for cleaning up make-exe by-products.
* automake/compile.am: Add *.ralf to clean-local.
* automake/compile.am: Remove .coff.
* automake/compile.am: Remove LINK_OBJS. Remove LINK_FILES.
Remove ARCH. Remove LINK_LIBS.
Extend clean-local to catch most temporary files make-exe is
creating.
Remove START_FILE, OBJS from LINK_FILES.
Don't manually set up GCCSPEC (Now setup from inside configure).
Remove RTEMS_RELLDFLAGS (Used).
* automake/compile.am: Remove CLEANDIRS (Unused).
Remove DEFS (Implicitly handled by automake).
* automake/compile.am: Remove CONFIG.CC (Unused).
Remove CPPFLAGS, CFLAGS, CXXFLAGS, ASFLAGS (Implicitly handled by
automake). Add CCAS. Use AM_*FLAGS = RTEMS_*FLAGS.
Remove LIB_VARIANT from LINK_*.
Cleanup comments.
* automake/compile.am: Remove AS, ASCOMPILE, make-rel (Unused).
Remove build-variants. Hard-code ARCH=o-optimize.
* automake/compile.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* aclocal/env-rtemsbsp.m4: Add PROJECT_LIB.
* automake/compile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* automake/compila.am: Remove ARCH.
* automake/compile.am: Add $(ARCH)/$(dirstamp) rules.
* aclocal/lead-dot.m4: New (from automake-1.7f).
* aclocal/rtems-top.m4: Require AM_SET_LEADING_DOT.
Add AC_SUBST(dirstamp).
* automake/local.am, automake/host.am: Remove "debug".
