* | Assume PROJECT_ROOT to contain RTEMS_BSP. | Ralf Corsepius | 2005-11-09 | 1 | -2/+2 |
* | Eliminate PROJECT_LIB. | Ralf Corsepius | 2005-11-09 | 1 | -4/+2 |
| | | | | Remove START_FILE, OBJS from LINK_FILES. | ||||
* | Remove RTEMS_CPPFLAGS, RTEMS_CFLAGS, RTEMS_CXXFLAGS. | Ralf Corsepius | 2005-11-08 | 1 | -3/+3 |
* | Cleanup. | Ralf Corsepius | 2005-11-08 | 1 | -2/+0 |
* | Remove RTEMS_BSP_SPECS, GCC_SPECS. | Ralf Corsepius | 2005-11-08 | 1 | -8/+0 |
| | | | | | Don't manually set up GCCSPEC (Now setup from inside configure). Remove RTEMS_RELLDFLAGS (Used). | ||||
* | Remove CCAS support. | Ralf Corsepius | 2005-11-08 | 1 | -4/+0 |
* | Remove depend-am. | Ralf Corsepius | 2005-11-07 | 1 | -3/+2 |
* | Remove depend. | Ralf Corsepius | 2005-11-07 | 1 | -2/+0 |
* | Remove depend-recursive. | Ralf Corsepius | 2005-11-07 | 1 | -4/+0 |
* | Take contents of amcompile.am. | Ralf Corsepius | 2005-11-07 | 1 | -64/+18 |
* | Remove | Ralf Corsepius | 2005-11-07 | 1 | -71/+0 |
* | New. | Ralf Corsepius | 2005-11-07 | 1 | -0/+71 |
* | 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-06 | 1 | -3/+1 |
| | | | | | * automake/compile.am: Remove CLEANDIRS (Unused). Remove DEFS (Implicitly handled by automake). | ||||
* | Remove duplicate CCAS. | Ralf Corsepius | 2005-01-06 | 1 | -1/+0 |
* | 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-06 | 1 | -57/+5 |
| | | | | | | | | * automake/compile.am: Remove CONFIG.CC (Unused). Remove CPPFLAGS, CFLAGS, CXXFLAGS, ASFLAGS (Implicitly handled by automake). Add CCAS. Use AM_*FLAGS = RTEMS_*FLAGS. Remove LIB_VARIANT from LINK_*. Cleanup comments. | ||||
* | 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-06 | 1 | -57/+3 |
| | | | | | * automake/compile.am: Remove AS, ASCOMPILE, make-rel (Unused). Remove build-variants. Hard-code ARCH=o-optimize. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-20 | 4 | -13/+12 |
* | 2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-17 | 1 | -1/+1 |
| | | | | * automake/compile.am: Use $(mkdir_p) instead of $(mkinstalldirs). | ||||
* | 2003-12-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-15 | 1 | -2/+2 |
| | | | | | * aclocal/env-rtemsbsp.m4: Add PROJECT_LIB. * automake/compile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -3/+0 |
| | | | | * automake/compila.am: Remove ARCH. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -3/+7 |
| | | | | | | | * automake/compile.am: Add $(ARCH)/$(dirstamp) rules. * aclocal/lead-dot.m4: New (from automake-1.7f). * aclocal/rtems-top.m4: Require AM_SET_LEADING_DOT. Add AC_SUBST(dirstamp). | ||||
* | 2003-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-17 | 2 | -16/+0 |
| | | | | * automake/local.am, automake/host.am: Remove "debug". | ||||
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 5 | -0/+318 |
* automake/compile.am, automake/host.am, automake/leaf.am automake/local.am, automake/subdirs.am: New (copied from ../../../automake). |
