* automake/compile.am: Remove CLEANDIRS (Unused).
Remove DEFS (Implicitly handled by automake).
* automake/compile.am: Remove CONFIG.CC (Unused).
Remove CPPFLAGS, CFLAGS, CXXFLAGS, ASFLAGS (Implicitly handled by
automake). Add CCAS. Use AM_*FLAGS = RTEMS_*FLAGS.
Remove LIB_VARIANT from LINK_*.
Cleanup comments.
* automake/compile.am: Remove AS, ASCOMPILE, make-rel (Unused).
Remove build-variants. Hard-code ARCH=o-optimize.
* automake/compile.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* aclocal/env-rtemsbsp.m4: Add PROJECT_LIB.
* automake/compile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* automake/compila.am: Remove ARCH.
* automake/compile.am: Add $(ARCH)/$(dirstamp) rules.
* aclocal/lead-dot.m4: New (from automake-1.7f).
* aclocal/rtems-top.m4: Require AM_SET_LEADING_DOT.
Add AC_SUBST(dirstamp).
* automake/compile.am, automake/host.am, automake/leaf.am
automake/local.am, automake/subdirs.am: New (copied from
../../../automake).
