These files had no file header, copyright, or license. Based on git
history, added appropriate copyright and license.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #4081.
Close #3250.
Close #4081.
Closes #4040.
Rename this header file to later move <t.h> to <rtems/test.h>. The main
feature provided by <rtems/test-info.h> is the output of standard test
information which is consumed by the RTEMS Tester.
Update #3199.
The CONFIGURE_DISABLE_SMP_CONFIGURATION configuration option and
rtems_configuration_is_smp_enabled() were added during the SMP support
development cycle as a workaround to fix some testsuite failures in SMP
configurations. All use cases were replaced with tests for specific
conditions. The configuration option and test macro were undocumented.
Close #3876.
Update #3845.
Update #3841.
Update #3818.
Provide an init.c for each Ada test instead of the #include <config.h>
magic which works only due to hand crafted include paths.
Update #3818.
Fix all warnings.
Update #3818.
Update #3818.
One reason to move the test support into a dedicated library are the
standard output __wrap_*() functions. They may conflict with
application level wrappers.
Update #3199.
Somehow it does not work. With this Automake option you get:
gmake[6]: Entering directory '/build/sparc-rtems5/c/erc32/testsuites/ada/sptests'
Making all-am in sp01
gmake[7]: Entering directory '/build/sparc-rtems5/c/erc32/testsuites/ada/sptests/sp01'
gmake[7]: *** No rule to make target 'init.o', needed by 'ada_sp01.exe'. Stop.
Update #3387.
upgrade to that version.
Close #3387.
Close #3320.
The SPTEST.RUN_COUNT must be volatile since it is changed outside of the
procedure scope by the thread switch extension.
Some time ago the Classic API object size related parameters were
changed to use size_t. Reflect this in the Ada bindings.
Update #3082.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3256.
A priority of zero is valid for the timer server.
Bug was introduced by d5154d0f6a04f3b7ed59d9a09038576fe2640756.
Updates #2493.
Most Ada tests fail otherwise.
Update #3020.
Reduce size of the big allocation block to account for the optional heap
protection (RTEMS_DEBUG).
Update #2676.
Update #3170.
Update #3199.
This solves a build dependency issue, e.g. building tests before
librtemsbsp.a exists.
Close #3079.
