2021-09-21 | build: Remove old build system | Sebastian Huber | 29 | -367/+0 | |
Close #3250. Close #4081. | |||||
2020-09-11 | Remove tmoverhd which existed to produce the obsolete coverhd.h | Joel Sherrill | 9 | -2963/+0 | |
Closes #4040. | |||||
2019-12-19 | config: Remove Ada configuration options | Sebastian Huber | 1 | -0/+4 | |
Update #3845. | |||||
2019-11-27 | testsuites/ada: Introduce init.c files | Sebastian Huber | 58 | -58/+58 | |
Provide an init.c for each Ada test instead of the #include <config.h> magic which works only due to hand crafted include paths. Update #3818. | |||||
2018-10-10 | build: Remove local.am | Sebastian Huber | 30 | -30/+0 | |
2018-01-29 | ada: Introduce RTEMS.Size type | Sebastian Huber | 7 | -11/+11 | |
Some time ago the Classic API object size related parameters were changed to use size_t. Reflect this in the Ada bindings. Update #3082. | |||||
2017-12-04 | ada/tm04: Account for task delete behaviour change | Sebastian Huber | 1 | -0/+9 | |
2017-12-01 | ada/tm20: Account for optional heap protection | Sebastian Huber | 1 | -3/+3 | |
Reduce size of the big allocation block to account for the optional heap protection (RTEMS_DEBUG). | |||||
2017-12-01 | ada: Add standard test begin/end message | Sebastian Huber | 58 | -58/+116 | |
2017-11-06 | tests: Use simple console driver | Sebastian Huber | 29 | -29/+29 | |
Update #3170. Update #3199. | |||||
2017-10-12 | ada-tests: Move to testsuites/ada | Sebastian Huber | 149 | -0/+15661 | |
This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079. |
