2024-03-20 | Do not define CONFIGURE_TICKS_PER_TIMESLICE to 0 | Sebastian Huber | 1 | -1/+0 | |
Unconditionally make a CONFIGURE_TICKS_PER_TIMESLICE value less than or equal to zero an error. Update #4986. | |||||
2022-04-12 | testsuites/ada/tmtests/tm2*: Change license to BSD-2 | Joel Sherrill | 4 | -12/+88 | |
Updates #3053. | |||||
2021-09-21 | build: Remove old build system | Sebastian Huber | 1 | -12/+0 | |
Close #3250. Close #4081. | |||||
2019-11-27 | testsuites/ada: Introduce init.c files | Sebastian Huber | 2 | -2/+2 | |
Provide an init.c for each Ada test instead of the #include <config.h> magic which works only due to hand crafted include paths. Update #3818. | |||||
2018-10-10 | build: Remove local.am | Sebastian Huber | 1 | -1/+0 | |
2017-12-01 | ada/tm20: Account for optional heap protection | Sebastian Huber | 1 | -3/+3 | |
Reduce size of the big allocation block to account for the optional heap protection (RTEMS_DEBUG). | |||||
2017-12-01 | ada: Add standard test begin/end message | Sebastian Huber | 2 | -2/+4 | |
2017-11-06 | tests: Use simple console driver | Sebastian Huber | 1 | -1/+1 | |
Update #3170. Update #3199. | |||||
2017-10-12 | ada-tests: Move to testsuites/ada | Sebastian Huber | 5 | -0/+707 | |
This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079. |
