* | ada: Introduce RTEMS.Size type | Sebastian Huber | 2018-01-29 | 1 | -1/+1 |
| | | | | | | | Some time ago the Classic API object size related parameters were changed to use size_t. Reflect this in the Ada bindings. Update #3082. | ||||
* | ada: Add standard test begin/end message | Sebastian Huber | 2017-12-01 | 2 | -2/+4 |
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | ada-tests: Move to testsuites/ada | Sebastian Huber | 2017-10-12 | 5 | -0/+410 |
This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079. |
