* | config: Remove Ada configuration options | Sebastian Huber | 2019-12-19 | 1 | -2/+0 |
| | | | | Update #3845. | ||||
* | rtems: Add and use rtems_object_get_local_node() | Sebastian Huber | 2019-12-13 | 1 | -2/+1 |
| | | | | Update #3841. | ||||
* | testsuites/ada: Introduce init.c files | Sebastian Huber | 2019-11-27 | 1 | -1/+1 |
| | | | | | | | Provide an init.c for each Ada test instead of the #include <config.h> magic which works only due to hand crafted include paths. Update #3818. | ||||
* | build: Remove local.am | Sebastian Huber | 2018-10-10 | 1 | -1/+0 |
* | build: Remove EXTRA_DIST | Sebastian Huber | 2018-04-04 | 1 | -16/+0 |
| | | | | | A "make dist" is not supported. So, it makes no sense to have pure "make dist" related stuff in the Makefile.am. | ||||
* | Add a simple task console driver | Sebastian Huber | 2018-03-06 | 1 | -0/+1 |
| | | | | Close #3320. | ||||
* | ada: Introduce RTEMS.Size type | Sebastian Huber | 2018-01-29 | 3 | -5/+5 |
| | | | | | | | Some time ago the Classic API object size related parameters were changed to use size_t. Reflect this in the Ada bindings. Update #3082. | ||||
* | ada: Check C and POSIX types | Sebastian Huber | 2017-12-04 | 2 | -0/+62 |
| | | | | Update #3256. | ||||
* | ada: Fix work_space_size() test support | Sebastian Huber | 2017-12-04 | 1 | -1/+2 |
* | ada: Use CONFIGURE_DISABLE_SMP_CONFIGURATION | Sebastian Huber | 2017-12-01 | 1 | -0/+2 |
| | | | | | | Most Ada tests fail otherwise. Update #3020. | ||||
* | ada: Add standard test begin/end message | Sebastian Huber | 2017-12-01 | 2 | -1/+23 |
* | ada-tests: Move to testsuites/ada | Sebastian Huber | 2017-10-12 | 16 | -0/+1365 |
This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079. |
