2019-11-29 | ada/sp19: Add m4 generated sptest.adb | Sebastian Huber | 2 | -0/+2996 | |
Update #3818. | |||||
2019-11-27 | testsuites/ada: Introduce init.c files | Sebastian Huber | 2 | -2/+2 | |
Provide an init.c for each Ada test instead of the #include <config.h> magic which works only due to hand crafted include paths. Update #3818. | |||||
2018-10-10 | build: Remove local.am | Sebastian Huber | 1 | -1/+0 | |
2017-12-02 | ada/sp19: Add missing FP attribute | Sebastian Huber | 1 | -2/+2 | |
2017-12-01 | ada: Add standard test begin/end message | Sebastian Huber | 2 | -2/+4 | |
2017-12-01 | ada: Delete superfluous CONFIGURE_SPTEST | Sebastian Huber | 1 | -2/+0 | |
2017-11-06 | tests: Use simple console driver | Sebastian Huber | 1 | -1/+1 | |
Update #3170. Update #3199. | |||||
2017-10-12 | ada-tests: Move to testsuites/ada | Sebastian Huber | 7 | -0/+695 | |
This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079. |
