* | testsuites/ada: Introduce init.c files | Sebastian Huber | 2019-11-27 | 2 | -2/+2 |
| | | | | | | | Provide an init.c for each Ada test instead of the #include <config.h> magic which works only due to hand crafted include paths. Update #3818. | ||||
* | build: Remove local.am | Sebastian Huber | 2018-10-10 | 1 | -1/+0 |
* | ada: Introduce RTEMS.Size type | Sebastian Huber | 2018-01-29 | 2 | -6/+8 |
| | | | | | | | Some time ago the Classic API object size related parameters were changed to use size_t. Reflect this in the Ada bindings. Update #3082. | ||||
* | ada/sp09: Fix timer server test case | Sebastian Huber | 2017-12-04 | 1 | -1/+1 |
| | | | | A priority of zero is valid for the timer server. | ||||
* | ada/sp09: Fix region test cases | Sebastian Huber | 2017-12-04 | 2 | -16/+17 |
* | ada: Add standard test begin/end message | Sebastian Huber | 2017-12-01 | 2 | -2/+4 |
* | ada: Delete superfluous CONFIGURE_SPTEST | Sebastian Huber | 2017-12-01 | 1 | -2/+0 |
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | ada-tests: Move to testsuites/ada | Sebastian Huber | 2017-10-12 | 6 | -0/+3870 |
This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079. |
