* | ada/sp07: Fix uninitialized variable | Sebastian Huber | 2017-12-01 | 1 | -0/+2 |
| | | | | | | Bug was introduced by d5154d0f6a04f3b7ed59d9a09038576fe2640756. Updates #2493. | ||||
* | ada: Fix user extension support | Sebastian Huber | 2017-12-01 | 1 | -2/+2 |
* | ada: Add standard test begin/end message | Sebastian Huber | 2017-12-01 | 2 | -2/+4 |
* | ada: Delete superfluous CONFIGURE_SPTEST | Sebastian Huber | 2017-12-01 | 1 | -2/+0 |
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | ada-tests: Move to testsuites/ada | Sebastian Huber | 2017-10-12 | 6 | -0/+835 |
This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079. |
