* | build: Remove old build system | Sebastian Huber | 2021-09-21 | 40 | -523/+0 |
| | | | | | Close #3250. Close #4081. | ||||
* | testsuites/ada: Introduce init.c files | Sebastian Huber | 2019-11-27 | 65 | -39/+39 |
| | | | | | | | Provide an init.c for each Ada test instead of the #include <config.h> magic which works only due to hand crafted include paths. Update #3818. | ||||
* | ada/mptests: Make them compile clean | Sebastian Huber | 2019-11-12 | 19 | -127/+195 |
| | | | | | | Fix all warnings. Update #3818. | ||||
* | build: Remove local.am | Sebastian Huber | 2018-10-10 | 40 | -40/+0 |
* | ada: Add standard test begin/end message | Sebastian Huber | 2017-12-01 | 26 | -27/+66 |
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 13 | -13/+13 |
| | | | | | Update #3170. Update #3199. | ||||
* | ada-tests: Move to testsuites/ada | Sebastian Huber | 2017-10-12 | 158 | -0/+8466 |
This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079. |
