path: root/testsuites/ada/configure.ac (follow)
* Remove tmoverhd which existed to produce the obsolete coverhd.hJoel Sherrill2020-09-111-1/+0
| | | | Closes #4040.
* build: Remove subdir-objects from Ada testsSebastian Huber2018-04-201-1/+1
| | | | | | | | | | | Somehow it does not work. With this Automake option you get: gmake[6]: Entering directory '/build/sparc-rtems5/c/erc32/testsuites/ada/sptests' Making all-am in sp01 gmake[7]: Entering directory '/build/sparc-rtems5/c/erc32/testsuites/ada/sptests/sp01' gmake[7]: *** No rule to make target 'init.o', needed by 'ada_sp01.exe'. Stop. Update #3387.
* configure: Add subdir-objects to all automake flags.Chris Johns2018-04-111-1/+1
| | | | | | | | | | | This option silences warning with automake-1.16.1 allowing us to upgrade to that version. This change has been tested with automake-1.12.6 and automake-1.16.1. It seems version 1.16.1 configures slower than 1.12.6 for the same source and BSP. The newer versions is 6 second slower. Close #3387.
* Remove make preinstallChris Johns2018-01-251-0/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254.
* ada-tests: Move to testsuites/adaSebastian Huber2017-10-121-0/+157
This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079.
