path: root/testsuites/aclocal (follow)
* build-system: Always enable C++ if the compiler is present.Chris Johns2016-08-112-19/+25
| | | | | | | | | | | We always build a C++ compiler and building with C++ does not effect RTEMS or the runtime. This patch always enabled the support. There is no need to manually enable it any more. You can disable C++ with '--disable-cxx'. If an architecture does not have a C++ compiler support is automatically disabled.
* Upgrade to 4.11.99.0Sebastian Huber2015-09-111-2/+2
* Add -std=gnu++11 to CXXFLAGS if SMP is enabledSebastian Huber2014-09-081-1/+6
| | | | | This is necessary to use the <atomic> header file used for the atomic operations.
* Add missing )Ralf Corsépius2012-05-181-1/+1
* Remove references to configure.in.Ralf Corsépius2012-05-181-1/+1
* Remove obsolete reference to posix bsp.Ralf Corsépius2012-05-181-1/+0
* Remove stray dnl.Ralf Corsépius2012-05-181-2/+0
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-1114-29/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-0714-0/+35
* Remove CVS-Ids.Ralf Corsépius2012-05-0414-35/+0
* 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-043-3/+3
| | | | | * aclocal/env-rtemsbsp.m4, aclocal/rtems-top.m4, aclocal/version.m4: Rename RTEMS_API into _RTEMS_API.
* 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-251-8/+10
| | | | | | | * aclocal/canonical-target-name.m4: Stop pretending no_cpu* was buildable. Derive RTEMS_CPU from "$host_cpu". Error out if "$host" doesn't match "*-*-rtems*".
* 2010-10-01 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-10-011-2/+2
| | | | | PR 1708/build: * aclocal/check-cpuopts.m4: Fix m4-quoting.
* 2010-09-23 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-09-231-2/+2
| | | | * aclocal/check-cpuopts.m4: Add AC_LANG_SOURCE.
* 2010-07-27 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-271-0/+3
| | | | | PR 1532/testing * aclocal/project-root.m4: Add initial tests for untar capabilities.
* 2010-06-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-071-2/+2
| | | | | * aclocal/version.m4: Bump RTEMS_API to 4.11. Bump _RTEMS_VERSION to 4.10.99.0.
* 2009-10-17 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-171-1/+2
| | | | * aclocal/check-custom-bsp.m4: Fix up AC_REQUIRES.
* 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-161-3/+0
| | | | * aclocal/canonical-target-name.m4: Remove RTEMS_HOST (unused).
* Remove posix/unix simulator.Ralf Corsepius2009-10-141-17/+0
* 2009-04-03 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-04-031-0/+4
| | | | | * aclocal/prog-cc.m4: Preset ac_cv_exeext=.exe for *-rtems* toolchains.
* Remove tic4x.Ralf Corsepius2008-12-221-4/+0
* 2008-09-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-221-2/+2
| | | | | * aclocal/version.m4: Bump RTEMS_API to 4.10. Bump _RTEMS_VERSION to 4.9.99.0.
* Require AC_DISABLE_OPTION_CHECKING. AC_PREREQ(2.62).Ralf Corsepius2008-07-021-0/+4
* s/AC_HELP/AS_HELP/.Ralf Corsepius2008-02-201-1/+1
* 2007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-09-211-2/+2
| | | | | * aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0.
* Upgrade to 4.7.99.2Joel Sherrill2007-08-071-1/+1
* Upgrade to 4.7.99.1Joel Sherrill2007-03-131-1/+1
* Revert to version 4.7.99-0Ralf Corsepius2007-02-221-1/+1
* Testing: Upgrade to 4.7.99.1Ralf Corsepius2007-02-221-1/+1
* 2007-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-02-111-1/+1
| | | | | * aclocal/check-cpuopts.m4: Check rtems/system.h instead of rtems/score/cpuopts.h.
* 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-182-2/+2
| | | | | * aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8.
* 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-171-0/+1
| | | | * aclocal/prog-cxx.m4: Add AC_PROG_CXXCPP.
* 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-171-1/+1
| | | | * aclocal/version.m4: Bump version to 4.7.99.0.
* 2006-04-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-04-181-1/+1
| | | | * aclocal/version.m4: Updated to rtems-4.6.99.3.
* 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-221-19/+0
| | | | * aclocal/enable-bare.m4: Remove (Unused).
* 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-221-4/+0
| | | | | | * aclocal/env-rtemsbsp.m4: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL.
* 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-131-4/+1
| | | | | * aclocal/env-rtemsbsp.m4: Remove includedir. Remove libdir. Set rtems_testsdir to $libdir/rtems-4.7/tests.
* 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-131-1/+0
| | | | * aclocal/env-rtemsbsp.m4: Remove RTEMS_CPU_MODEL.
* Remove project_libdir. Remove project_includedir. Add rtems_testsdir.Ralf Corsepius2005-11-131-2/+1
* Remove dirstamp.Ralf Corsepius2005-11-131-2/+0
* Remove (Unused).Ralf Corsepius2005-11-099-183/+0
* Apply cpukit_root, project_root to set up GCCSPECS.Ralf Corsepius2005-11-091-1/+4
* Apply cpukit_root, project_root to set up temporary CPPFLAGS to compile ↵Ralf Corsepius2005-11-091-0/+10
| | | | check cpuopts.h.
* Add --enable-cpukit-root, --enable-project-root. Remove --with-project-root. ↵Ralf Corsepius2005-11-091-5/+37
| | | | Fix --enable-rtems-root.
* Assume PROJECT_ROOT to contain RTEMS_BSP.Ralf Corsepius2005-11-091-3/+3
* Remove CPLUS_LD_LIBS.Ralf Corsepius2005-11-091-5/+0
* Add config.cache support.Ralf Corsepius2005-11-091-6/+8
* 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-091-0/+14
| | | | * aclocal/check-cpuopts.m4: New.
* Remove (Unused).Ralf Corsepius2005-11-081-25/+0
* Remove RTEMS_CFLAGSRalf Corsepius2005-11-081-8/+0
