path: root/testsuites/aclocal (follow)
* 2009-10-17 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-171-1/+2
| | | | * aclocal/check-custom-bsp.m4: Fix up AC_REQUIRES.
* 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-161-3/+0
| | | | * aclocal/canonical-target-name.m4: Remove RTEMS_HOST (unused).
* Remove posix/unix simulator.Ralf Corsepius2009-10-141-17/+0
* 2009-04-03 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-04-031-0/+4
| | | | | * aclocal/prog-cc.m4: Preset ac_cv_exeext=.exe for *-rtems* toolchains.
* Remove tic4x.Ralf Corsepius2008-12-221-4/+0
* 2008-09-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-221-2/+2
| | | | | * aclocal/version.m4: Bump RTEMS_API to 4.10. Bump _RTEMS_VERSION to 4.9.99.0.
* Require AC_DISABLE_OPTION_CHECKING. AC_PREREQ(2.62).Ralf Corsepius2008-07-021-0/+4
* s/AC_HELP/AS_HELP/.Ralf Corsepius2008-02-201-1/+1
* 2007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-09-211-2/+2
| | | | | * aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0.
* Upgrade to 4.7.99.2Joel Sherrill2007-08-071-1/+1
* Upgrade to 4.7.99.1Joel Sherrill2007-03-131-1/+1
* Revert to version 4.7.99-0Ralf Corsepius2007-02-221-1/+1
* Testing: Upgrade to 4.7.99.1Ralf Corsepius2007-02-221-1/+1
* 2007-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-02-111-1/+1
| | | | | * aclocal/check-cpuopts.m4: Check rtems/system.h instead of rtems/score/cpuopts.h.
* 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-182-2/+2
| | | | | * aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8.
* 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-171-0/+1
| | | | * aclocal/prog-cxx.m4: Add AC_PROG_CXXCPP.
* 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-171-1/+1
| | | | * aclocal/version.m4: Bump version to 4.7.99.0.
* 2006-04-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-04-181-1/+1
| | | | * aclocal/version.m4: Updated to rtems-4.6.99.3.
* 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-221-19/+0
| | | | * aclocal/enable-bare.m4: Remove (Unused).
* 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-221-4/+0
| | | | | | * aclocal/env-rtemsbsp.m4: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL.
* 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-131-4/+1
| | | | | * aclocal/env-rtemsbsp.m4: Remove includedir. Remove libdir. Set rtems_testsdir to $libdir/rtems-4.7/tests.
* 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-131-1/+0
| | | | * aclocal/env-rtemsbsp.m4: Remove RTEMS_CPU_MODEL.
* Remove project_libdir. Remove project_includedir. Add rtems_testsdir.Ralf Corsepius2005-11-131-2/+1
* Remove dirstamp.Ralf Corsepius2005-11-131-2/+0
* Remove (Unused).Ralf Corsepius2005-11-099-183/+0
* Apply cpukit_root, project_root to set up GCCSPECS.Ralf Corsepius2005-11-091-1/+4
* Apply cpukit_root, project_root to set up temporary CPPFLAGS to compile ↵Ralf Corsepius2005-11-091-0/+10
| | | | check cpuopts.h.
* Add --enable-cpukit-root, --enable-project-root. Remove --with-project-root. ↵Ralf Corsepius2005-11-091-5/+37
| | | | Fix --enable-rtems-root.
* Assume PROJECT_ROOT to contain RTEMS_BSP.Ralf Corsepius2005-11-091-3/+3
* Remove CPLUS_LD_LIBS.Ralf Corsepius2005-11-091-5/+0
* Add config.cache support.Ralf Corsepius2005-11-091-6/+8
* 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-091-0/+14
| | | | * aclocal/check-cpuopts.m4: New.
* Remove (Unused).Ralf Corsepius2005-11-081-25/+0
* Remove RTEMS_CFLAGSRalf Corsepius2005-11-081-8/+0
* Add GCCSPECS. Remove RTEMS_CPPFLAGS.Ralf Corsepius2005-11-081-6/+5
* Remove GCCSPECS.Ralf Corsepius2005-11-081-5/+0
* CleanupRalf Corsepius2005-11-081-1/+0
* Remove RTEMS_USE_GCC.Ralf Corsepius2005-11-081-7/+0
| | | | Remove RTEMS_GCC_PIPE. Remove RTEMS_GCC_SPECS.
* Remove (Unused).Ralf Corsepius2005-11-082-41/+0
* Merge RTEMS_BSP_SPECS and GCC_SPECS into GCCSPECS.Ralf Corsepius2005-11-081-5/+4
* Don't provide MULTILIB conditional.Ralf Corsepius2005-11-081-2/+0
* Don't require RTEMS_ENABLE_MULTILIB.Ralf Corsepius2005-11-081-1/+0
* Remove (Unused).Ralf Corsepius2005-11-081-16/+0
* Sync with cpukit.Ralf Corsepius2005-11-071-13/+0
* Remove.Ralf Corsepius2005-11-074-112/+0
* 2005-09-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-09-021-1/+1
| | | | * aclocal/version.m4: Updated to rtems-4.6.99.2.
* 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-061-0/+3
| | | | * aclocal/prog-cxx.m4: Re-add am__fastdepCXX conditional.
* 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-061-11/+0
| | | | * aclocal/rtems-flags.m4: Remove (Unused).
* 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-063-13/+5
| | | | | | | | | | * aclocal/env-rtemsbsp.m4: Remove CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V. * aclocal/prog-cc.m4: Don't invoke _RTEMS_FLAGS to set up RTEMS_CFLAGS. * aclocal/prog-cxx.m4: Let CXXFLAGS default to CFLAGS. Don't invoke _RTEMS_FLAGS to set up RTEMS_CXXFLAGS. Remove am__fastdepCXX conditional.
* 2004-11-22 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2004-11-222-44/+2
| | | | | * aclocal/enable-itron.m4, aclocal/check-itron.m4: Allow building itron for unix.
