* | Upgrade to 4.11.99.0 | Sebastian Huber | 2015-09-11 | 1 | -2/+2 |
* | Add -std=gnu++11 to CXXFLAGS if SMP is enabled | Sebastian Huber | 2014-09-08 | 1 | -1/+6 |
| | | | | | This is necessary to use the <atomic> header file used for the atomic operations. | ||||
* | Add missing ) | Ralf Corsépius | 2012-05-18 | 1 | -1/+1 |
* | Remove references to configure.in. | Ralf Corsépius | 2012-05-18 | 1 | -1/+1 |
* | Remove obsolete reference to posix bsp. | Ralf Corsépius | 2012-05-18 | 1 | -1/+0 |
* | Remove stray dnl. | Ralf Corsépius | 2012-05-18 | 1 | -2/+0 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 14 | -29/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 14 | -0/+35 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 14 | -35/+0 |
* | 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-04 | 3 | -3/+3 |
| | | | | | * aclocal/env-rtemsbsp.m4, aclocal/rtems-top.m4, aclocal/version.m4: Rename RTEMS_API into _RTEMS_API. | ||||
* | 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-25 | 1 | -8/+10 |
| | | | | | | | * aclocal/canonical-target-name.m4: Stop pretending no_cpu* was buildable. Derive RTEMS_CPU from "$host_cpu". Error out if "$host" doesn't match "*-*-rtems*". | ||||
* | 2010-10-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-10-01 | 1 | -2/+2 |
| | | | | | PR 1708/build: * aclocal/check-cpuopts.m4: Fix m4-quoting. | ||||
* | 2010-09-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-09-23 | 1 | -2/+2 |
| | | | | * aclocal/check-cpuopts.m4: Add AC_LANG_SOURCE. | ||||
* | 2010-07-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-07-27 | 1 | -0/+3 |
| | | | | | PR 1532/testing * aclocal/project-root.m4: Add initial tests for untar capabilities. | ||||
* | 2010-06-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-07 | 1 | -2/+2 |
| | | | | | * aclocal/version.m4: Bump RTEMS_API to 4.11. Bump _RTEMS_VERSION to 4.10.99.0. | ||||
* | 2009-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-17 | 1 | -1/+2 |
| | | | | * aclocal/check-custom-bsp.m4: Fix up AC_REQUIRES. | ||||
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 1 | -3/+0 |
| | | | | * aclocal/canonical-target-name.m4: Remove RTEMS_HOST (unused). | ||||
* | Remove posix/unix simulator. | Ralf Corsepius | 2009-10-14 | 1 | -17/+0 |
* | 2009-04-03 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-04-03 | 1 | -0/+4 |
| | | | | | * aclocal/prog-cc.m4: Preset ac_cv_exeext=.exe for *-rtems* toolchains. | ||||
* | Remove tic4x. | Ralf Corsepius | 2008-12-22 | 1 | -4/+0 |
* | 2008-09-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-22 | 1 | -2/+2 |
| | | | | | * aclocal/version.m4: Bump RTEMS_API to 4.10. Bump _RTEMS_VERSION to 4.9.99.0. | ||||
* | Require AC_DISABLE_OPTION_CHECKING. AC_PREREQ(2.62). | Ralf Corsepius | 2008-07-02 | 1 | -0/+4 |
* | s/AC_HELP/AS_HELP/. | Ralf Corsepius | 2008-02-20 | 1 | -1/+1 |
* | 2007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-09-21 | 1 | -2/+2 |
| | | | | | * aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0. | ||||
* | Upgrade to 4.7.99.2 | Joel Sherrill | 2007-08-07 | 1 | -1/+1 |
* | Upgrade to 4.7.99.1 | Joel Sherrill | 2007-03-13 | 1 | -1/+1 |
* | Revert to version 4.7.99-0 | Ralf Corsepius | 2007-02-22 | 1 | -1/+1 |
* | Testing: Upgrade to 4.7.99.1 | Ralf Corsepius | 2007-02-22 | 1 | -1/+1 |
* | 2007-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-02-11 | 1 | -1/+1 |
| | | | | | * aclocal/check-cpuopts.m4: Check rtems/system.h instead of rtems/score/cpuopts.h. | ||||
* | 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-18 | 2 | -2/+2 |
| | | | | | * aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -0/+1 |
| | | | | * aclocal/prog-cxx.m4: Add AC_PROG_CXXCPP. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Bump version to 4.7.99.0. | ||||
* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-18 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.3. | ||||
* | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-22 | 1 | -19/+0 |
| | | | | * aclocal/enable-bare.m4: Remove (Unused). | ||||
* | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-22 | 1 | -4/+0 |
| | | | | | | * aclocal/env-rtemsbsp.m4: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL. | ||||
* | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-13 | 1 | -4/+1 |
| | | | | | * aclocal/env-rtemsbsp.m4: Remove includedir. Remove libdir. Set rtems_testsdir to $libdir/rtems-4.7/tests. | ||||
* | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-13 | 1 | -1/+0 |
| | | | | * aclocal/env-rtemsbsp.m4: Remove RTEMS_CPU_MODEL. | ||||
* | Remove project_libdir. Remove project_includedir. Add rtems_testsdir. | Ralf Corsepius | 2005-11-13 | 1 | -2/+1 |
* | Remove dirstamp. | Ralf Corsepius | 2005-11-13 | 1 | -2/+0 |
* | Remove (Unused). | Ralf Corsepius | 2005-11-09 | 9 | -183/+0 |
* | Apply cpukit_root, project_root to set up GCCSPECS. | Ralf Corsepius | 2005-11-09 | 1 | -1/+4 |
* | Apply cpukit_root, project_root to set up temporary CPPFLAGS to compile ↵ | Ralf Corsepius | 2005-11-09 | 1 | -0/+10 |
| | | | | check cpuopts.h. | ||||
* | Add --enable-cpukit-root, --enable-project-root. Remove --with-project-root. ↵ | Ralf Corsepius | 2005-11-09 | 1 | -5/+37 |
| | | | | Fix --enable-rtems-root. | ||||
* | Assume PROJECT_ROOT to contain RTEMS_BSP. | Ralf Corsepius | 2005-11-09 | 1 | -3/+3 |
* | Remove CPLUS_LD_LIBS. | Ralf Corsepius | 2005-11-09 | 1 | -5/+0 |
* | Add config.cache support. | Ralf Corsepius | 2005-11-09 | 1 | -6/+8 |
* | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 1 | -0/+14 |
| | | | | * aclocal/check-cpuopts.m4: New. | ||||
* | Remove (Unused). | Ralf Corsepius | 2005-11-08 | 1 | -25/+0 |
* | Remove RTEMS_CFLAGS | Ralf Corsepius | 2005-11-08 | 1 | -8/+0 |
* | Add GCCSPECS. Remove RTEMS_CPPFLAGS. | Ralf Corsepius | 2005-11-08 | 1 | -6/+5 |
