* aclocal/rtems-cpu-subdirs.m4: mips64orion port removed as mips port
more completely covers the MIPS family.
* aclocal/version.m4: Updated to rtems-20031217-test.
* aclocal/env-rtemsbsp.m4: Add PROJECT_LIB.
* automake/compile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* aclocal/lead-dot.m4: Remove (Provided by automake-1.8).
* aclocal/env-rtemsbsp.m4: Remove bsplibdir.
Cleanups.
* automake/compile.am: Add $(ARCH)/$(dirstamp) rules.
* aclocal/lead-dot.m4: New (from automake-1.7f).
* aclocal/rtems-top.m4: Require AM_SET_LEADING_DOT.
Add AC_SUBST(dirstamp).
* aclocal/canonical-target-name.m4, aclocal/canonicalize-tools.m4,
aclocal/check-custom-bsp.m4, aclocal/check-cxx.m4,
aclocal/check-itron.m4, aclocal/check-multiprocessing.m4,
aclocal/check-networking.m4, aclocal/check-posix.m4,
aclocal/check-tool.m4, aclocal/config-subdirs.m4,
aclocal/enable-bare.m4, aclocal/enable-cxx.m4,
aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4,
aclocal/enable-networking.m4, aclocal/enable-posix.m4,
aclocal/enable-rtemsbsp.m4, aclocal/enable-tests.m4,
aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4,
aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4,
aclocal/multilib.m4, aclocal/path-ksh.m4,
aclocal/prog-cc.m4, aclocal/prog-cxx.m4,
aclocal/project-root.m4, aclocal/rtems-test-no-pause.m4,
aclocal/rtems-top.m4, aclocal/target.m4,
aclocal/tool-paths.m4:
Fix underquoting to silence automake-1.8.
* aclocal/rtems-top.m4: Add support for --with-project-root.
Remove RTEMS Version message.
* aclocal/canonical-host.m4: Remove.
* aclocal/canonical-target-name.m4: Merge-in aclocal/canonical-host.m4.
* aclocal/check-multiprocessing.m4: Don't require RTEMS_BSP_ALIAS.
* aclocal/bsp_alias.m4: Remove.
* configure.ac:Remove RTEMS_CHECK_CPU.
* aclocal/check-cpu.m4: Remove.
* aclocal/check-cxx.m4, aclocal/check-itron.m4,
aclocal/check-multiprocessing.m4, aclocal/check-networking.m4,
aclocal/check-posix.m4: AC_REQUIRE RTEMS_CANONICAL_TARGET_CPU instead of
RTEMS_CHECK_CPU.
* aclocal/rtems-top.m4: Add RTEMS_API.
AC_DEFAULT_PREFIX([/opt/rtems-][RTEMS_API]).
* aclocal/check-tests.m4: New (Split out from enable-tests.m4).
* aclocal/enable-tests.m4: Change to support
--enable-tests=no|yes|samples, default is samples.
* aclocal/bsp-alias.m4: New (Copied from ../../../aclocal).
* aclocal/canonical-host.m4: New (Copied from ../../../aclocal).
* aclocal/canonicalize-tools.m4: New (Copied from ../../../aclocal).
* aclocal/canonical-target-name.m4: New (Copied from ../../../aclocal).
* aclocal/check-cpu.m4: New (Copied from ../../../aclocal).
* aclocal/check-custom-bsp.m4: New (Copied from ../../../aclocal).
* aclocal/check-cxx.m4: New (Copied from ../../../aclocal).
* aclocal/check-itron.m4: New (Copied from ../../../aclocal).
* aclocal/check-multiprocessing.m4: New (Copied from ../../../aclocal).
* aclocal/check-networking.m4: New (Copied from ../../../aclocal).
* aclocal/check-posix.m4: New (Copied from ../../../aclocal).
* aclocal/check-tool.m4: New (Copied from ../../../aclocal).
* aclocal/config-subdirs.m4: New (Copied from ../../../aclocal).
* aclocal/enable-bare.m4: New (Copied from ../../../aclocal).
* aclocal/enable-cxx.m4: New (Copied from ../../../aclocal).
* aclocal/enable-itron.m4: New (Copied from ../../../aclocal).
* aclocal/enable-multiprocessing.m4: New (Copied from ../../../aclocal).
* aclocal/enable-networking.m4: New (Copied from ../../../aclocal).
* aclocal/enable-posix.m4: New (Copied from ../../../aclocal).
* aclocal/enable-rtemsbsp.m4: New (Copied from ../../../aclocal).
* aclocal/enable-tests.m4: New (Copied from ../../../aclocal).
* aclocal/env-rtemsbsp.m4: New (Copied from ../../../aclocal).
* aclocal/gcc-isystem.m4: New (Copied from ../../../aclocal).
* aclocal/gcc-pipe.m4: New (Copied from ../../../aclocal).
* aclocal/gcc-specs.m4: New (Copied from ../../../aclocal).
* aclocal/multilib.m4: New (Copied from ../../../aclocal).
* aclocal/path-ksh.m4: New (Copied from ../../../aclocal).
* aclocal/prog-cc.m4: New (Copied from ../../../aclocal).
* aclocal/prog-cxx.m4: New (Copied from ../../../aclocal).
* aclocal/project-root.m4: New (Copied from ../../../aclocal).
* aclocal/quoting.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-flags.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-test-no-pause.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-top.m4: New (Copied from ../../../aclocal).
* aclocal/target.m4: New (Copied from ../../../aclocal).
* aclocal/tool-paths.m4: New (Copied from ../../../aclocal).
* aclocal/version.m4: New (Copied from ../../../aclocal).
