path: root/testsuites/aclocal (follow)
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-121-1/+1
| | | | * aclocal/version.m4: 4.6.99.0.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-071-1/+0
| | | | | * aclocal/rtems-cpu-subdirs.m4: mips64orion port removed as mips port more completely covers the MIPS family.
* 2003-12-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-12-171-1/+1
| | | | * aclocal/version.m4: Updated to rtems-20031217-test.
* 2003-12-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-151-0/+1
| | | | | * aclocal/env-rtemsbsp.m4: Add PROJECT_LIB. * automake/compile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-40/+5
| | | | | | * aclocal/lead-dot.m4: Remove (Provided by automake-1.8). * aclocal/env-rtemsbsp.m4: Remove bsplibdir. Cleanups.
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-012-0/+35
| | | | | | | * automake/compile.am: Add $(ARCH)/$(dirstamp) rules. * aclocal/lead-dot.m4: New (from automake-1.7f). * aclocal/rtems-top.m4: Require AM_SET_LEADING_DOT. Add AC_SUBST(dirstamp).
* 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-2631-40/+40
| | | | | | | | | | | | | | | | | | | | * aclocal/canonical-target-name.m4, aclocal/canonicalize-tools.m4, aclocal/check-custom-bsp.m4, aclocal/check-cxx.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-networking.m4, aclocal/check-posix.m4, aclocal/check-tool.m4, aclocal/config-subdirs.m4, aclocal/enable-bare.m4, aclocal/enable-cxx.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rtemsbsp.m4, aclocal/enable-tests.m4, aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4, aclocal/multilib.m4, aclocal/path-ksh.m4, aclocal/prog-cc.m4, aclocal/prog-cxx.m4, aclocal/project-root.m4, aclocal/rtems-test-no-pause.m4, aclocal/rtems-top.m4, aclocal/target.m4, aclocal/tool-paths.m4: Fix underquoting to silence automake-1.8.
* 2003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-231-9/+3
| | | | | * aclocal/rtems-top.m4: Add support for --with-project-root. Remove RTEMS Version message.
* 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-221-3/+11
| | | | | * aclocal/canonical-host.m4: Remove. * aclocal/canonical-target-name.m4: Merge-in aclocal/canonical-host.m4.
* 2003-10-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-201-1/+0
| | | | | * aclocal/check-multiprocessing.m4: Don't require RTEMS_BSP_ALIAS. * aclocal/bsp_alias.m4: Remove.
* 2003-10-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-025-5/+5
| | | | | | | | | * configure.ac:Remove RTEMS_CHECK_CPU. * aclocal/check-cpu.m4: Remove. * aclocal/check-cxx.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-networking.m4, aclocal/check-posix.m4: AC_REQUIRE RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU.
* 2003-08-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-291-1/+3
| | | | | * aclocal/rtems-top.m4: Add RTEMS_API. AC_DEFAULT_PREFIX([/opt/rtems-][RTEMS_API]).
* 2003-08-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-221-0/+5
| | | | * aclocal/check-tests.m4: New (Split out from enable-tests.m4).
* 2003-08-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-221-8/+6
| | | | | | * aclocal/enable-tests.m4: Change to support --enable-tests=no|yes|samples, default is samples. * configure.ac: Reflect changes above.
* 2003-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-1835-0/+1013
* aclocal/bsp-alias.m4: New (Copied from ../../../aclocal). * aclocal/canonical-host.m4: New (Copied from ../../../aclocal). * aclocal/canonicalize-tools.m4: New (Copied from ../../../aclocal). * aclocal/canonical-target-name.m4: New (Copied from ../../../aclocal). * aclocal/check-cpu.m4: New (Copied from ../../../aclocal). * aclocal/check-custom-bsp.m4: New (Copied from ../../../aclocal). * aclocal/check-cxx.m4: New (Copied from ../../../aclocal). * aclocal/check-itron.m4: New (Copied from ../../../aclocal). * aclocal/check-multiprocessing.m4: New (Copied from ../../../aclocal). * aclocal/check-networking.m4: New (Copied from ../../../aclocal). * aclocal/check-posix.m4: New (Copied from ../../../aclocal). * aclocal/check-tool.m4: New (Copied from ../../../aclocal). * aclocal/config-subdirs.m4: New (Copied from ../../../aclocal). * aclocal/enable-bare.m4: New (Copied from ../../../aclocal). * aclocal/enable-cxx.m4: New (Copied from ../../../aclocal). * aclocal/enable-itron.m4: New (Copied from ../../../aclocal). * aclocal/enable-multiprocessing.m4: New (Copied from ../../../aclocal). * aclocal/enable-networking.m4: New (Copied from ../../../aclocal). * aclocal/enable-posix.m4: New (Copied from ../../../aclocal). * aclocal/enable-rtemsbsp.m4: New (Copied from ../../../aclocal). * aclocal/enable-tests.m4: New (Copied from ../../../aclocal). * aclocal/env-rtemsbsp.m4: New (Copied from ../../../aclocal). * aclocal/gcc-isystem.m4: New (Copied from ../../../aclocal). * aclocal/gcc-pipe.m4: New (Copied from ../../../aclocal). * aclocal/gcc-specs.m4: New (Copied from ../../../aclocal). * aclocal/multilib.m4: New (Copied from ../../../aclocal). * aclocal/path-ksh.m4: New (Copied from ../../../aclocal). * aclocal/prog-cc.m4: New (Copied from ../../../aclocal). * aclocal/prog-cxx.m4: New (Copied from ../../../aclocal). * aclocal/project-root.m4: New (Copied from ../../../aclocal). * aclocal/quoting.m4: New (Copied from ../../../aclocal). * aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../../aclocal). * aclocal/rtems-flags.m4: New (Copied from ../../../aclocal). * aclocal/rtems-test-no-pause.m4: New (Copied from ../../../aclocal). * aclocal/rtems-top.m4: New (Copied from ../../../aclocal). * aclocal/target.m4: New (Copied from ../../../aclocal). * aclocal/tool-paths.m4: New (Copied from ../../../aclocal). * aclocal/version.m4: New (Copied from ../../../aclocal).
