* | 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-18 | 2 | -2/+2 |
| | | | | | * aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -0/+1 |
| | | | | * aclocal/prog-cxx.m4: Add AC_PROG_CXXCPP. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Bump version to 4.7.99.0. | ||||
* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-18 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.3. | ||||
* | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-22 | 1 | -19/+0 |
| | | | | * aclocal/enable-bare.m4: Remove (Unused). | ||||
* | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-22 | 1 | -4/+0 |
| | | | | | | * aclocal/env-rtemsbsp.m4: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL. | ||||
* | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-13 | 1 | -4/+1 |
| | | | | | * aclocal/env-rtemsbsp.m4: Remove includedir. Remove libdir. Set rtems_testsdir to $libdir/rtems-4.7/tests. | ||||
* | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-13 | 1 | -1/+0 |
| | | | | * aclocal/env-rtemsbsp.m4: Remove RTEMS_CPU_MODEL. | ||||
* | Remove project_libdir. Remove project_includedir. Add rtems_testsdir. | Ralf Corsepius | 2005-11-13 | 1 | -2/+1 |
* | Remove dirstamp. | Ralf Corsepius | 2005-11-13 | 1 | -2/+0 |
* | Remove (Unused). | Ralf Corsepius | 2005-11-09 | 9 | -183/+0 |
* | Apply cpukit_root, project_root to set up GCCSPECS. | Ralf Corsepius | 2005-11-09 | 1 | -1/+4 |
* | Apply cpukit_root, project_root to set up temporary CPPFLAGS to compile ↵ | Ralf Corsepius | 2005-11-09 | 1 | -0/+10 |
| | | | | check cpuopts.h. | ||||
* | Add --enable-cpukit-root, --enable-project-root. Remove --with-project-root. ↵ | Ralf Corsepius | 2005-11-09 | 1 | -5/+37 |
| | | | | Fix --enable-rtems-root. | ||||
* | Assume PROJECT_ROOT to contain RTEMS_BSP. | Ralf Corsepius | 2005-11-09 | 1 | -3/+3 |
* | Remove CPLUS_LD_LIBS. | Ralf Corsepius | 2005-11-09 | 1 | -5/+0 |
* | Add config.cache support. | Ralf Corsepius | 2005-11-09 | 1 | -6/+8 |
* | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 1 | -0/+14 |
| | | | | * aclocal/check-cpuopts.m4: New. | ||||
* | Remove (Unused). | Ralf Corsepius | 2005-11-08 | 1 | -25/+0 |
* | Remove RTEMS_CFLAGS | Ralf Corsepius | 2005-11-08 | 1 | -8/+0 |
* | Add GCCSPECS. Remove RTEMS_CPPFLAGS. | Ralf Corsepius | 2005-11-08 | 1 | -6/+5 |
* | Remove GCCSPECS. | Ralf Corsepius | 2005-11-08 | 1 | -5/+0 |
* | Cleanup | Ralf Corsepius | 2005-11-08 | 1 | -1/+0 |
* | Remove RTEMS_USE_GCC. | Ralf Corsepius | 2005-11-08 | 1 | -7/+0 |
| | | | | Remove RTEMS_GCC_PIPE. Remove RTEMS_GCC_SPECS. | ||||
* | Remove (Unused). | Ralf Corsepius | 2005-11-08 | 2 | -41/+0 |
* | Merge RTEMS_BSP_SPECS and GCC_SPECS into GCCSPECS. | Ralf Corsepius | 2005-11-08 | 1 | -5/+4 |
* | Don't provide MULTILIB conditional. | Ralf Corsepius | 2005-11-08 | 1 | -2/+0 |
* | Don't require RTEMS_ENABLE_MULTILIB. | Ralf Corsepius | 2005-11-08 | 1 | -1/+0 |
* | Remove (Unused). | Ralf Corsepius | 2005-11-08 | 1 | -16/+0 |
* | Sync with cpukit. | Ralf Corsepius | 2005-11-07 | 1 | -13/+0 |
* | Remove. | Ralf Corsepius | 2005-11-07 | 4 | -112/+0 |
* | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-09-02 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.2. | ||||
* | 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-06 | 1 | -0/+3 |
| | | | | * aclocal/prog-cxx.m4: Re-add am__fastdepCXX conditional. | ||||
* | 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-06 | 1 | -11/+0 |
| | | | | * aclocal/rtems-flags.m4: Remove (Unused). | ||||
* | 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-06 | 3 | -13/+5 |
| | | | | | | | | | | * aclocal/env-rtemsbsp.m4: Remove CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V. * aclocal/prog-cc.m4: Don't invoke _RTEMS_FLAGS to set up RTEMS_CFLAGS. * aclocal/prog-cxx.m4: Let CXXFLAGS default to CFLAGS. Don't invoke _RTEMS_FLAGS to set up RTEMS_CXXFLAGS. Remove am__fastdepCXX conditional. | ||||
* | 2004-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2004-11-22 | 2 | -44/+2 |
| | | | | | * aclocal/enable-itron.m4, aclocal/check-itron.m4: Allow building itron for unix. | ||||
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 1 | -29/+0 |
| | | | | * aclocal/rtems-cpu-subdirs.m4: Remove (unused). | ||||
* | 2004-07-28 | Joel Sherrill | 2004-07-28 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.1. | ||||
* | 2004-04-14 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-14 | 1 | -1/+5 |
| | | | | * aclocal/rtems-top.m4: Add project_top/with_project_top processing. | ||||
* | 2004-03-28 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-28 | 1 | -1/+1 |
| | | | | * aclocal/rtems-top.m4: s/RTEMS_RTEMS/RTEMS_ROOT (typo). | ||||
* | 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-03-25 | 1 | -1/+1 |
| | | | | * aclocal/check-custom-bsp.m4: Fix minor typo. | ||||
* | 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-03-25 | 2 | -5/+8 |
| | | | | | * aclocal/rtems-top.m4: Add rtems_rootdir. * aclocal/check-custom-bsp.m4: Check for $RTEMS_BSP.cfg in $rtems_rootdir. | ||||
* | 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-03-25 | 1 | -14/+19 |
| | | | | | | * aclocal/rtems-top.m4: Add 2nd arg to RTEMS_TOP. Rework with_project_root/PROJECT_ROOT and with_project_top/PROJECT_TOPdir. Add --enable-rtems-root. Rework RTEMS_ROOT. | ||||
* | 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-03-25 | 9 | -15/+10 |
| | | | | | | | | * aclocal/enable-bare.m4, aclocal/enable-cxx.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-tests.m4, aclocal/multilib.m4, aclocal/rtems-test-no-pause.m4: Autoupdate to autoconf-2.59. | ||||
* | 2004-02-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-19 | 4 | -31/+27 |
| | | | | | | | | * configure.ac: AC_CONFIG_SRCDIR([PROBLEMS]). * aclocal/check-custom-bsp.m4: Sync with c/src/aclocal. * aclocal/project-root.m4: Remove obsolete comments. * aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT. * aclocal/rtems-top.m4: Rework. | ||||
* | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-14 | 1 | -138/+0 |
| | | | | * aclocal/target.m4: Remove (Unused). | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: 4.6.99.0. | ||||
* | 2004-01-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-01-07 | 1 | -1/+0 |
| | | | | | * aclocal/rtems-cpu-subdirs.m4: mips64orion port removed as mips port more completely covers the MIPS family. | ||||
* | 2003-12-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-12-17 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-20031217-test. | ||||
* | 2003-12-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-15 | 1 | -0/+1 |
| | | | | | * aclocal/env-rtemsbsp.m4: Add PROJECT_LIB. * automake/compile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. |
