2009-11-13 | Upgrade to 4.9.34.9.3 | Joel Sherrill | 1 | -1/+1 | |
2009-03-12 | Upgrade to 4.9.2 | Joel Sherrill | 1 | -1/+1 | |
2008-12-12 | Upgrade to 4.9.1 | Joel Sherrill | 1 | -1/+1 | |
2008-09-24 | Upgrade to 4.9.0 | Joel Sherrill | 1 | -1/+1 | |
2008-09-10 | 2008-09-10 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -4/+0 | |
* aclocal/canonical-target-name.m4: Remove TI C4x and NIOS2 ports from 4.9 branch. | |||||
2008-07-02 | Require AC_DISABLE_OPTION_CHECKING. AC_PREREQ(2.62). | Ralf Corsepius | 1 | -0/+4 | |
2008-02-20 | s/AC_HELP/AS_HELP/. | Ralf Corsepius | 1 | -1/+1 | |
2007-09-21 | 2007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0. | |||||
2007-08-07 | Upgrade to 4.7.99.2 | Joel Sherrill | 1 | -1/+1 | |
2007-03-13 | Upgrade to 4.7.99.1 | Joel Sherrill | 1 | -1/+1 | |
2007-02-22 | Revert to version 4.7.99-0 | Ralf Corsepius | 1 | -1/+1 | |
2007-02-22 | Testing: Upgrade to 4.7.99.1 | Ralf Corsepius | 1 | -1/+1 | |
2007-02-11 | 2007-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* aclocal/check-cpuopts.m4: Check rtems/system.h instead of rtems/score/cpuopts.h. | |||||
2006-10-18 | 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+2 | |
* aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8. | |||||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* aclocal/prog-cxx.m4: Add AC_PROG_CXXCPP. | |||||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* aclocal/version.m4: Bump version to 4.7.99.0. | |||||
2006-04-18 | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* aclocal/version.m4: Updated to rtems-4.6.99.3. | |||||
2005-11-22 | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -19/+0 | |
* aclocal/enable-bare.m4: Remove (Unused). | |||||
2005-11-22 | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -4/+0 | |
* aclocal/env-rtemsbsp.m4: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL. | |||||
2005-11-13 | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -4/+1 | |
* aclocal/env-rtemsbsp.m4: Remove includedir. Remove libdir. Set rtems_testsdir to $libdir/rtems-4.7/tests. | |||||
2005-11-13 | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+0 | |
* aclocal/env-rtemsbsp.m4: Remove RTEMS_CPU_MODEL. | |||||
2005-11-13 | Remove project_libdir. Remove project_includedir. Add rtems_testsdir. | Ralf Corsepius | 1 | -2/+1 | |
2005-11-13 | Remove dirstamp. | Ralf Corsepius | 1 | -2/+0 | |
2005-11-09 | Remove (Unused). | Ralf Corsepius | 9 | -183/+0 | |
2005-11-09 | Apply cpukit_root, project_root to set up GCCSPECS. | Ralf Corsepius | 1 | -1/+4 | |
2005-11-09 | Apply cpukit_root, project_root to set up temporary CPPFLAGS to compile ↵ | Ralf Corsepius | 1 | -0/+10 | |
check cpuopts.h. | |||||
2005-11-09 | Add --enable-cpukit-root, --enable-project-root. Remove --with-project-root. ↵ | Ralf Corsepius | 1 | -5/+37 | |
Fix --enable-rtems-root. | |||||
2005-11-09 | Assume PROJECT_ROOT to contain RTEMS_BSP. | Ralf Corsepius | 1 | -3/+3 | |
2005-11-09 | Remove CPLUS_LD_LIBS. | Ralf Corsepius | 1 | -5/+0 | |
2005-11-09 | Add config.cache support. | Ralf Corsepius | 1 | -6/+8 | |
2005-11-09 | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+14 | |
* aclocal/check-cpuopts.m4: New. | |||||
2005-11-08 | Remove (Unused). | Ralf Corsepius | 1 | -25/+0 | |
2005-11-08 | Remove RTEMS_CFLAGS | Ralf Corsepius | 1 | -8/+0 | |
2005-11-08 | Add GCCSPECS. Remove RTEMS_CPPFLAGS. | Ralf Corsepius | 1 | -6/+5 | |
2005-11-08 | Remove GCCSPECS. | Ralf Corsepius | 1 | -5/+0 | |
2005-11-08 | Cleanup | Ralf Corsepius | 1 | -1/+0 | |
2005-11-08 | Remove RTEMS_USE_GCC. | Ralf Corsepius | 1 | -7/+0 | |
Remove RTEMS_GCC_PIPE. Remove RTEMS_GCC_SPECS. | |||||
2005-11-08 | Remove (Unused). | Ralf Corsepius | 2 | -41/+0 | |
2005-11-08 | Merge RTEMS_BSP_SPECS and GCC_SPECS into GCCSPECS. | Ralf Corsepius | 1 | -5/+4 | |
2005-11-08 | Don't provide MULTILIB conditional. | Ralf Corsepius | 1 | -2/+0 | |
2005-11-08 | Don't require RTEMS_ENABLE_MULTILIB. | Ralf Corsepius | 1 | -1/+0 | |
2005-11-08 | Remove (Unused). | Ralf Corsepius | 1 | -16/+0 | |
2005-11-07 | Sync with cpukit. | Ralf Corsepius | 1 | -13/+0 | |
2005-11-07 | Remove. | Ralf Corsepius | 4 | -112/+0 | |
2005-09-02 | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* aclocal/version.m4: Updated to rtems-4.6.99.2. | |||||
2005-01-06 | 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+3 | |
* aclocal/prog-cxx.m4: Re-add am__fastdepCXX conditional. | |||||
2005-01-06 | 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -11/+0 | |
* aclocal/rtems-flags.m4: Remove (Unused). | |||||
2005-01-06 | 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 3 | -13/+5 | |
* aclocal/env-rtemsbsp.m4: Remove CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V. * aclocal/prog-cc.m4: Don't invoke _RTEMS_FLAGS to set up RTEMS_CFLAGS. * aclocal/prog-cxx.m4: Let CXXFLAGS default to CFLAGS. Don't invoke _RTEMS_FLAGS to set up RTEMS_CXXFLAGS. Remove am__fastdepCXX conditional. | |||||
2004-11-22 | 2004-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -44/+2 | |
* aclocal/enable-itron.m4, aclocal/check-itron.m4: Allow building itron for unix. | |||||
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -29/+0 | |
* aclocal/rtems-cpu-subdirs.m4: Remove (unused). |
