2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 14 | -29/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2012-05-07 | Revert: Remove CVS Ids | Joel Sherrill | 14 | -0/+35 | |
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | |||||
2012-05-04 | Remove CVS-Ids. | Ralf Corsépius | 14 | -35/+0 | |
2011-03-04 | 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 3 | -3/+3 | |
* aclocal/env-rtemsbsp.m4, aclocal/rtems-top.m4, aclocal/version.m4: Rename RTEMS_API into _RTEMS_API. | |||||
2011-02-25 | 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -8/+10 | |
* aclocal/canonical-target-name.m4: Stop pretending no_cpu* was buildable. Derive RTEMS_CPU from "$host_cpu". Error out if "$host" doesn't match "*-*-rtems*". | |||||
2010-10-01 | 2010-10-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
PR 1708/build: * aclocal/check-cpuopts.m4: Fix m4-quoting. | |||||
2010-09-23 | 2010-09-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* aclocal/check-cpuopts.m4: Add AC_LANG_SOURCE. | |||||
2010-07-27 | 2010-07-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+3 | |
PR 1532/testing * aclocal/project-root.m4: Add initial tests for untar capabilities. | |||||
2010-06-07 | 2010-06-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* aclocal/version.m4: Bump RTEMS_API to 4.11. Bump _RTEMS_VERSION to 4.10.99.0. | |||||
2009-10-17 | 2009-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+2 | |
* aclocal/check-custom-bsp.m4: Fix up AC_REQUIRES. | |||||
2009-10-16 | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -3/+0 | |
* aclocal/canonical-target-name.m4: Remove RTEMS_HOST (unused). | |||||
2009-10-14 | Remove posix/unix simulator. | Ralf Corsepius | 1 | -17/+0 | |
2009-04-03 | 2009-04-03 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/prog-cc.m4: Preset ac_cv_exeext=.exe for *-rtems* toolchains. | |||||
2008-12-22 | Remove tic4x. | Ralf Corsepius | 1 | -4/+0 | |
2008-09-22 | 2008-09-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* aclocal/version.m4: Bump RTEMS_API to 4.10. Bump _RTEMS_VERSION to 4.9.99.0. | |||||
2008-07-02 | Require AC_DISABLE_OPTION_CHECKING. AC_PREREQ(2.62). | Ralf Corsepius | 1 | -0/+4 | |
2008-02-20 | s/AC_HELP/AS_HELP/. | Ralf Corsepius | 1 | -1/+1 | |
2007-09-21 | 2007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0. | |||||
2007-08-07 | Upgrade to 4.7.99.2 | Joel Sherrill | 1 | -1/+1 | |
2007-03-13 | Upgrade to 4.7.99.1 | Joel Sherrill | 1 | -1/+1 | |
2007-02-22 | Revert to version 4.7.99-0 | Ralf Corsepius | 1 | -1/+1 | |
2007-02-22 | Testing: Upgrade to 4.7.99.1 | Ralf Corsepius | 1 | -1/+1 | |
2007-02-11 | 2007-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* aclocal/check-cpuopts.m4: Check rtems/system.h instead of rtems/score/cpuopts.h. | |||||
2006-10-18 | 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+2 | |
* aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8. | |||||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* aclocal/prog-cxx.m4: Add AC_PROG_CXXCPP. | |||||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* aclocal/version.m4: Bump version to 4.7.99.0. | |||||
2006-04-18 | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* aclocal/version.m4: Updated to rtems-4.6.99.3. | |||||
2005-11-22 | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -19/+0 | |
* aclocal/enable-bare.m4: Remove (Unused). | |||||
2005-11-22 | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -4/+0 | |
* aclocal/env-rtemsbsp.m4: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL. | |||||
2005-11-13 | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -4/+1 | |
* aclocal/env-rtemsbsp.m4: Remove includedir. Remove libdir. Set rtems_testsdir to $libdir/rtems-4.7/tests. | |||||
2005-11-13 | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+0 | |
* aclocal/env-rtemsbsp.m4: Remove RTEMS_CPU_MODEL. | |||||
2005-11-13 | Remove project_libdir. Remove project_includedir. Add rtems_testsdir. | Ralf Corsepius | 1 | -2/+1 | |
2005-11-13 | Remove dirstamp. | Ralf Corsepius | 1 | -2/+0 | |
2005-11-09 | Remove (Unused). | Ralf Corsepius | 9 | -183/+0 | |
2005-11-09 | Apply cpukit_root, project_root to set up GCCSPECS. | Ralf Corsepius | 1 | -1/+4 | |
2005-11-09 | Apply cpukit_root, project_root to set up temporary CPPFLAGS to compile ↵ | Ralf Corsepius | 1 | -0/+10 | |
check cpuopts.h. | |||||
2005-11-09 | Add --enable-cpukit-root, --enable-project-root. Remove --with-project-root. ↵ | Ralf Corsepius | 1 | -5/+37 | |
Fix --enable-rtems-root. | |||||
2005-11-09 | Assume PROJECT_ROOT to contain RTEMS_BSP. | Ralf Corsepius | 1 | -3/+3 | |
2005-11-09 | Remove CPLUS_LD_LIBS. | Ralf Corsepius | 1 | -5/+0 | |
2005-11-09 | Add config.cache support. | Ralf Corsepius | 1 | -6/+8 | |
2005-11-09 | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+14 | |
* aclocal/check-cpuopts.m4: New. | |||||
2005-11-08 | Remove (Unused). | Ralf Corsepius | 1 | -25/+0 | |
2005-11-08 | Remove RTEMS_CFLAGS | Ralf Corsepius | 1 | -8/+0 | |
2005-11-08 | Add GCCSPECS. Remove RTEMS_CPPFLAGS. | Ralf Corsepius | 1 | -6/+5 | |
2005-11-08 | Remove GCCSPECS. | Ralf Corsepius | 1 | -5/+0 | |
2005-11-08 | Cleanup | Ralf Corsepius | 1 | -1/+0 | |
2005-11-08 | Remove RTEMS_USE_GCC. | Ralf Corsepius | 1 | -7/+0 | |
Remove RTEMS_GCC_PIPE. Remove RTEMS_GCC_SPECS. | |||||
2005-11-08 | Remove (Unused). | Ralf Corsepius | 2 | -41/+0 | |
2005-11-08 | Merge RTEMS_BSP_SPECS and GCC_SPECS into GCCSPECS. | Ralf Corsepius | 1 | -5/+4 | |
2005-11-08 | Don't provide MULTILIB conditional. | Ralf Corsepius | 1 | -2/+0 | |
