Update #4020.
Updates #2962
The rtems_test_pause() and rtems_test_pause_and_screen_number() macros
had different implementations depending on the RTEMS_TEST_NO_PAUSE
define. This define was defined to 1 by default. The user was able to
change this via the undocumented --disable-test-no-pause configure
command line option.
Pausing tests and waiting for user input contradicts the goal of having
automated test runs. Remove this feature.
Update #3818.
- Add a small memory test config file.
- Update the small memory PowerPC BSPs to use the new test config.
Closes #3579
This is needed for building rtems correctly with Clang.
Note that this change does not mean rtems can build correctly with
mainline clang. However the change allows building rtems with a
Clang toolchain that has a rtems frontend similar that of GCC's
builtin rtems specs.
All tools should be removed from the RTEMS source repository at some
point in time. Tools with a BSD-style license will be moved to the
RTEMS tools repository. Unfortunately, this tool has no license
information.
Remove all uses of this tool from the code base. Users of HEX files
should consider to use ELF instead.
Close #3379.
This tool is now included in the RTEMS tools repository.
Close #3380.
Remove shell script variant.
Update #3285.
Update #3285.
Also generate an error if the architecure does not match the --target
architecture given to configure's command line.
Close #2641.
The autoconf function checks the state of a test for the BSP and
controls the building of the test.
This change is part of the testsuite Makefile.am reorganisation.
Update #3382
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3109.
This fixes the legacy Makefile based build system which expects
RTEMS_API to be identical to the tool chain version.
Update #3220.
Tool name will be "rtems5", e.g. arm-rtems5-gcc.
Next release will 5.1.0. Branch version after release will be 5.1.1.
Next master will be 6.0.0.
Closes #3181.
We always build a C++ compiler and building with C++ does not effect
RTEMS or the runtime. This patch always enabled the support. There is
no need to manually enable it any more.
You can disable C++ with '--disable-cxx'.
If an architecture does not have a C++ compiler support is automatically
disabled.
This is necessary to use the <atomic> header file used for the atomic
operations.
for details.
* aclocal/env-rtemsbsp.m4, aclocal/rtems-top.m4, aclocal/version.m4:
Rename RTEMS_API into _RTEMS_API.
* aclocal/canonical-target-name.m4:
Stop pretending no_cpu* was buildable.
Derive RTEMS_CPU from "$host_cpu".
Error out if "$host" doesn't match "*-*-rtems*".
PR 1708/build:
* aclocal/check-cpuopts.m4: Fix m4-quoting.
* aclocal/check-cpuopts.m4: Add AC_LANG_SOURCE.
PR 1532/testing
* aclocal/project-root.m4: Add initial tests for untar capabilities.
* aclocal/version.m4: Bump RTEMS_API to 4.11.
Bump _RTEMS_VERSION to 4.10.99.0.
* aclocal/check-custom-bsp.m4: Fix up AC_REQUIRES.
* aclocal/canonical-target-name.m4: Remove RTEMS_HOST (unused).
* aclocal/prog-cc.m4: Preset ac_cv_exeext=.exe for *-rtems*
toolchains.
* aclocal/version.m4: Bump RTEMS_API to 4.10.
Bump _RTEMS_VERSION to 4.9.99.0.
* aclocal/version.m4: Bump RTEMS_API to 4.9.
Bump RTEMS_VERSION to 4.8.99.0.
* aclocal/check-cpuopts.m4: Check rtems/system.h instead of
rtems/score/cpuopts.h.
* aclocal/rtems-top.m4: Remove RTEMS_API.
* aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8.
