* aclocal/rtems-cpu-subdirs.m4: Remove (unused).
* aclocal/rtems-cpu-subdirs.m4: mips64orion port removed as mips port
more completely covers the MIPS family.
* aclocal/bsp-alias.m4: New (Copied from ../../../aclocal).
* aclocal/canonical-host.m4: New (Copied from ../../../aclocal).
* aclocal/canonicalize-tools.m4: New (Copied from ../../../aclocal).
* aclocal/canonical-target-name.m4: New (Copied from ../../../aclocal).
* aclocal/check-cpu.m4: New (Copied from ../../../aclocal).
* aclocal/check-custom-bsp.m4: New (Copied from ../../../aclocal).
* aclocal/check-cxx.m4: New (Copied from ../../../aclocal).
* aclocal/check-itron.m4: New (Copied from ../../../aclocal).
* aclocal/check-multiprocessing.m4: New (Copied from ../../../aclocal).
* aclocal/check-networking.m4: New (Copied from ../../../aclocal).
* aclocal/check-posix.m4: New (Copied from ../../../aclocal).
* aclocal/check-tool.m4: New (Copied from ../../../aclocal).
* aclocal/config-subdirs.m4: New (Copied from ../../../aclocal).
* aclocal/enable-bare.m4: New (Copied from ../../../aclocal).
* aclocal/enable-cxx.m4: New (Copied from ../../../aclocal).
* aclocal/enable-itron.m4: New (Copied from ../../../aclocal).
* aclocal/enable-multiprocessing.m4: New (Copied from ../../../aclocal).
* aclocal/enable-networking.m4: New (Copied from ../../../aclocal).
* aclocal/enable-posix.m4: New (Copied from ../../../aclocal).
* aclocal/enable-rtemsbsp.m4: New (Copied from ../../../aclocal).
* aclocal/enable-tests.m4: New (Copied from ../../../aclocal).
* aclocal/env-rtemsbsp.m4: New (Copied from ../../../aclocal).
* aclocal/gcc-isystem.m4: New (Copied from ../../../aclocal).
* aclocal/gcc-pipe.m4: New (Copied from ../../../aclocal).
* aclocal/gcc-specs.m4: New (Copied from ../../../aclocal).
* aclocal/multilib.m4: New (Copied from ../../../aclocal).
* aclocal/path-ksh.m4: New (Copied from ../../../aclocal).
* aclocal/prog-cc.m4: New (Copied from ../../../aclocal).
* aclocal/prog-cxx.m4: New (Copied from ../../../aclocal).
* aclocal/project-root.m4: New (Copied from ../../../aclocal).
* aclocal/quoting.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-flags.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-test-no-pause.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-top.m4: New (Copied from ../../../aclocal).
* aclocal/target.m4: New (Copied from ../../../aclocal).
* aclocal/tool-paths.m4: New (Copied from ../../../aclocal).
* aclocal/version.m4: New (Copied from ../../../aclocal).
* README.configure, aclocal/rtems-cpu-subdirs.m4: Remove a29k
references.
* aclocal/rtems-cpu-subdirs.m4: Print out RTEMS_CPU in error message.
* aclocal/enable-cxx.m4: Use $enable_cxx instead of $enableval.
* aclocal/rtems-cpu-subdirs.m4: Removed the or16 port
was just a stub and only the OR32 port is getting worked on.
* aclocal/rtems-cpu-subdirs.m4: Add PREFIX arg to RTEMS_CPU_SUBDIRS,
add 2nd arg to _RTEMS_CPU_SUBDIR.
* aclocal/target.m4: Replace ac_configure_args with
rtems_configure_args, add rtems_configure_args to INIT-CMDS.
* aclocal/rtems-cpu-subdirs.m4: New file.
