path: root/testsuites/aclocal/rtems-bsp-linkcmds.m4 (follow)
* bsps: Move startup files to bspsSebastian Huber2018-04-201-2/+2
| | | | | | | | Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285.
* Remove make preinstallChris Johns2018-01-251-0/+25
