* | 2004-02-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-19 | 1 | -3/+0 |
| | | | | | | | | * configure.ac: AC_CONFIG_SRCDIR([PROBLEMS]). * aclocal/check-custom-bsp.m4: Sync with c/src/aclocal. * aclocal/project-root.m4: Remove obsolete comments. * aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT. * aclocal/rtems-top.m4: Rework. | ||||
* | 2003-12-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-15 | 1 | -0/+1 |
| | | | | | * aclocal/env-rtemsbsp.m4: Add PROJECT_LIB. * automake/compile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -8/+5 |
| | | | | | | * aclocal/lead-dot.m4: Remove (Provided by automake-1.8). * aclocal/env-rtemsbsp.m4: Remove bsplibdir. Cleanups. | ||||
* | 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-26 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | * aclocal/canonical-target-name.m4, aclocal/canonicalize-tools.m4, aclocal/check-custom-bsp.m4, aclocal/check-cxx.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-networking.m4, aclocal/check-posix.m4, aclocal/check-tool.m4, aclocal/config-subdirs.m4, aclocal/enable-bare.m4, aclocal/enable-cxx.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rtemsbsp.m4, aclocal/enable-tests.m4, aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4, aclocal/multilib.m4, aclocal/path-ksh.m4, aclocal/prog-cc.m4, aclocal/prog-cxx.m4, aclocal/project-root.m4, aclocal/rtems-test-no-pause.m4, aclocal/rtems-top.m4, aclocal/target.m4, aclocal/tool-paths.m4: Fix underquoting to silence automake-1.8. | ||||
* | 2003-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 1 | -0/+56 |
* aclocal/bsp-alias.m4: New (Copied from ../../../aclocal). * aclocal/canonical-host.m4: New (Copied from ../../../aclocal). * aclocal/canonicalize-tools.m4: New (Copied from ../../../aclocal). * aclocal/canonical-target-name.m4: New (Copied from ../../../aclocal). * aclocal/check-cpu.m4: New (Copied from ../../../aclocal). * aclocal/check-custom-bsp.m4: New (Copied from ../../../aclocal). * aclocal/check-cxx.m4: New (Copied from ../../../aclocal). * aclocal/check-itron.m4: New (Copied from ../../../aclocal). * aclocal/check-multiprocessing.m4: New (Copied from ../../../aclocal). * aclocal/check-networking.m4: New (Copied from ../../../aclocal). * aclocal/check-posix.m4: New (Copied from ../../../aclocal). * aclocal/check-tool.m4: New (Copied from ../../../aclocal). * aclocal/config-subdirs.m4: New (Copied from ../../../aclocal). * aclocal/enable-bare.m4: New (Copied from ../../../aclocal). * aclocal/enable-cxx.m4: New (Copied from ../../../aclocal). * aclocal/enable-itron.m4: New (Copied from ../../../aclocal). * aclocal/enable-multiprocessing.m4: New (Copied from ../../../aclocal). * aclocal/enable-networking.m4: New (Copied from ../../../aclocal). * aclocal/enable-posix.m4: New (Copied from ../../../aclocal). * aclocal/enable-rtemsbsp.m4: New (Copied from ../../../aclocal). * aclocal/enable-tests.m4: New (Copied from ../../../aclocal). * aclocal/env-rtemsbsp.m4: New (Copied from ../../../aclocal). * aclocal/gcc-isystem.m4: New (Copied from ../../../aclocal). * aclocal/gcc-pipe.m4: New (Copied from ../../../aclocal). * aclocal/gcc-specs.m4: New (Copied from ../../../aclocal). * aclocal/multilib.m4: New (Copied from ../../../aclocal). * aclocal/path-ksh.m4: New (Copied from ../../../aclocal). * aclocal/prog-cc.m4: New (Copied from ../../../aclocal). * aclocal/prog-cxx.m4: New (Copied from ../../../aclocal). * aclocal/project-root.m4: New (Copied from ../../../aclocal). * aclocal/quoting.m4: New (Copied from ../../../aclocal). * aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../../aclocal). * aclocal/rtems-flags.m4: New (Copied from ../../../aclocal). * aclocal/rtems-test-no-pause.m4: New (Copied from ../../../aclocal). * aclocal/rtems-top.m4: New (Copied from ../../../aclocal). * aclocal/target.m4: New (Copied from ../../../aclocal). * aclocal/tool-paths.m4: New (Copied from ../../../aclocal). * aclocal/version.m4: New (Copied from ../../../aclocal). |
