path: root/testsuites/aclocal/check-cxx.m4 (unfollow)
2021-11-29*/aclocal/*: Remove remnants of autoconf/automae build systemJoel Sherrill1-20/+0
Updates #4081.
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-1/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2012-05-07Revert: Remove CVS IdsJoel Sherrill1-0/+2
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details.
2012-05-04Remove CVS-Ids.Ralf Corsépius1-2/+0
2005-11-09Remove CPLUS_LD_LIBS.Ralf Corsepius1-5/+0
2003-11-262003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+1
* aclocal/canonical-target-name.m4, aclocal/canonicalize-tools.m4, aclocal/check-custom-bsp.m4, aclocal/check-cxx.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-networking.m4, aclocal/check-posix.m4, aclocal/check-tool.m4, aclocal/config-subdirs.m4, aclocal/enable-bare.m4, aclocal/enable-cxx.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rtemsbsp.m4, aclocal/enable-tests.m4, aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4, aclocal/multilib.m4, aclocal/path-ksh.m4, aclocal/prog-cc.m4, aclocal/prog-cxx.m4, aclocal/project-root.m4, aclocal/rtems-test-no-pause.m4, aclocal/rtems-top.m4, aclocal/target.m4, aclocal/tool-paths.m4: Fix underquoting to silence automake-1.8.
2003-10-022003-10-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+1
* configure.ac:Remove RTEMS_CHECK_CPU. * aclocal/check-cpu.m4: Remove. * aclocal/check-cxx.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-networking.m4, aclocal/check-posix.m4: AC_REQUIRE RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU.
2003-08-182003-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-0/+0
* aclocal/bsp-alias.m4: New (Copied from ../../../aclocal). * aclocal/canonical-host.m4: New (Copied from ../../../aclocal). * aclocal/canonicalize-tools.m4: New (Copied from ../../../aclocal). * aclocal/canonical-target-name.m4: New (Copied from ../../../aclocal). * aclocal/check-cpu.m4: New (Copied from ../../../aclocal). * aclocal/check-custom-bsp.m4: New (Copied from ../../../aclocal). * aclocal/check-cxx.m4: New (Copied from ../../../aclocal). * aclocal/check-itron.m4: New (Copied from ../../../aclocal). * aclocal/check-multiprocessing.m4: New (Copied from ../../../aclocal). * aclocal/check-networking.m4: New (Copied from ../../../aclocal). * aclocal/check-posix.m4: New (Copied from ../../../aclocal). * aclocal/check-tool.m4: New (Copied from ../../../aclocal). * aclocal/config-subdirs.m4: New (Copied from ../../../aclocal). * aclocal/enable-bare.m4: New (Copied from ../../../aclocal). * aclocal/enable-cxx.m4: New (Copied from ../../../aclocal). * aclocal/enable-itron.m4: New (Copied from ../../../aclocal). * aclocal/enable-multiprocessing.m4: New (Copied from ../../../aclocal). * aclocal/enable-networking.m4: New (Copied from ../../../aclocal). * aclocal/enable-posix.m4: New (Copied from ../../../aclocal). * aclocal/enable-rtemsbsp.m4: New (Copied from ../../../aclocal). * aclocal/enable-tests.m4: New (Copied from ../../../aclocal). * aclocal/env-rtemsbsp.m4: New (Copied from ../../../aclocal). * aclocal/gcc-isystem.m4: New (Copied from ../../../aclocal). * aclocal/gcc-pipe.m4: New (Copied from ../../../aclocal). * aclocal/gcc-specs.m4: New (Copied from ../../../aclocal). * aclocal/multilib.m4: New (Copied from ../../../aclocal). * aclocal/path-ksh.m4: New (Copied from ../../../aclocal). * aclocal/prog-cc.m4: New (Copied from ../../../aclocal). * aclocal/prog-cxx.m4: New (Copied from ../../../aclocal). * aclocal/project-root.m4: New (Copied from ../../../aclocal). * aclocal/quoting.m4: New (Copied from ../../../aclocal). * aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../../aclocal). * aclocal/rtems-flags.m4: New (Copied from ../../../aclocal). * aclocal/rtems-test-no-pause.m4: New (Copied from ../../../aclocal). * aclocal/rtems-top.m4: New (Copied from ../../../aclocal). * aclocal/target.m4: New (Copied from ../../../aclocal). * aclocal/tool-paths.m4: New (Copied from ../../../aclocal). * aclocal/version.m4: New (Copied from ../../../aclocal).
2003-05-162003-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+1
* aclocal/check-cxx.m4: Remove LIBSUFFIX_VA. * automake/compile.am: Remove LIBSUFFIX_VA. Merger from rtems-4-6-branch.
2000-11-022000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* aclocal/*: Replace with contents of macros/*.m4 * macros/: Remove. * aclocal/ar-s.m4 aclocal/tool-prefix.m4: Remove. * Makefile.am: Reflect changes to aclocal/ and macros/.
2000-09-122000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
* aclocal/check-cxx.m4: Add AC_SUBST(CPLUS_LD_LIBS) * aclocal/prog-cc.m4: Cleanup comments, require RTEMS_ENABLE_GCC28, add automake conditionals RTEMS_USE_GCC, RTEMS_USE_GCC272. * automake/compile.am: Replaced. * automake/local.am: Remove building variant handling.
1999-09-07Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1-0/+1
Ralf Corsepius <corsepiu@faw.uni-ulm.de> which converted many Makefile.in's to Makefile.am's. This added a lot of files.
1999-08-10New configuration files added by patch fromJoel Sherrill1-0/+20
