for details.
* Makefile.am: Add support/include/tmtests_empty_function.h.
* support/include/primode.h: New.
* Makefile.am: Add support/include/primode.h
* support/include/pritime.h: New.
* Makefile.am: Add support/include/pritime.h
* Makefile.am: Don't preinstall support/include headers.
Addtional major bugs:
