2009-10-27 | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* support/include/tmacros.h: Add PRIxpthread_t. | |||||
2009-10-27 | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* support/include/tmacros.h: Add PRIxrtems_event_set. (fatal_posix_service_status_errno) Add local "long" var "statx". | |||||
* support/include/tmacros.h: Add PRIdThread_Entry_numeric_type. Add PRIdrtems_task_argument. | |||||
2009-10-26 | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* support/include/tmacros.h: Add PRIdWatchdog_Interval. Add PRIdrtems_interval. | |||||
* support/include/tmacros.h: Add PRIdPriority_Control. Change PRIdrtems_task_priority to using PRIdPriority_Control. | |||||
2009-10-26 | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* support/include/tmacros.h: Add PRIdrtems_task_priority. | |||||
* support/include/tmacros.h: Add PRIxrtems_id. | |||||
* support/include/tmacros.h: Add PRItime_t. | |||||
* support/include/tmacros.h (print_time): Use PRIu32 instead of %d. | |||||
2009-10-26 | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* support/include/test_support.h: Add missing prototypes. | |||||
* support/include/tmacros.h: Move _Thread_Dispatch_disable_level outside of check_dispatch_disable_level. | |||||
* support/src/test_support.c: Add missing prototypes. | |||||
2009-10-26 | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -57/+63 | |
* support/include/tmacros.h: Include <inttypes.h>. Move extern "C". Let put_name use "int" instead "uint32_t" (Arg to putchar must be int). | |||||
2009-10-24 | 2009-10-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Add support/include/test_support.h. | |||||
2009-10-23 | 2009-10-23 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* automake/compile.am: Add *.ralf to clean-local. | |||||
2009-10-17 | 2009-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/check-custom-bsp.m4: Fix up AC_REQUIRES. | |||||
2009-10-16 | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/canonical-target-name.m4: Remove RTEMS_HOST (unused). | |||||
2009-10-14 | 2009-10-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/canonical-target-name.m4: Remove posix/unix simulator. | |||||
2009-09-14 | 2009-09-14 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -0/+6 | |
* psxtests/psxclock/init.c, psxtests/psxclock/psxclock.scn: Add test case for nanosleep of a very small delay which mathematically is less than a clock tick. | |||||
2009-09-13 | 2009-09-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+6 | |
* configure.ac: Some POSIX tests exercise functionality which is enabled when the POSIX threading is disabled. So build this suite all the time and let the psxtests select the specific tests to build. | |||||
2009-08-12 | 2009-08-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+6 | |
* support/include/tmacros.h: Eliminate test routines TICKS_PER_SECOND and get_ticks_per_second() in favor of new rtems_clock_get_ticks_per_second(). | |||||
2009-08-06 | 2009-08-06 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* support/src/test_support.c: Tinker with longest valid name. | |||||
2009-08-06 | 2009-08-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* support/include/buffer_test_io.h: Use printk on AVR by default. | |||||
2009-05-10 | 2009-05-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* support/src/tmtests_empty_function.c: Fix warnings. | |||||
2009-04-03 | 2009-04-03 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/prog-cc.m4: Preset ac_cv_exeext=.exe for *-rtems* toolchains. | |||||
2008-12-22 | 2008-12-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/canonical-target-name.m4: Remove tic4x. | |||||
2008-09-22 | 2008-09-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/version.m4: Bump RTEMS_API to 4.10. Bump _RTEMS_VERSION to 4.9.99.0. | |||||
2008-09-06 | 2008-09-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* support/src/test_support.c: Convert to "bool". | |||||
2008-08-31 | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* support/src/tmtests_empty_function.c: New file. | |||||
2008-07-02 | 2008-07-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/rtems-top.m4: Require AC_DISABLE_OPTION_CHECKING. AC_PREREQ(2.62). | |||||
2008-02-20 | 2008-02-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/enable-rtemsbsp.m4: s/AC_HELP/AS_HELP/. | |||||
2008-02-04 | 2008-02-04 Jennifer Averett <jennifer.averett@OARcorp.com> | Jennifer Averett | 1 | -0/+4 | |
* support/include/test_support.h, support/src/test_support.c: New files. | |||||
2008-02-01 | 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -0/+6 | |
* support/include/tmacros.h: Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a clock_settime case for < 1988. | |||||
2008-01-31 | 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* support/include/tmacros.h: Fix put_name to handle unprintable names. | |||||
2008-01-29 | 2008-01-29 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* support/include/tmacros.h: Add new rtems_test_assert() which exits rather than calling fatal error. | |||||
2007-12-17 | 2007-12-17 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* support/include/tmacros.h: Add new helper for POSIX tests. | |||||
2007-09-21 | 2007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0. | |||||
2007-05-11 | 2007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -0/+6 | |
* support/include/buffer_test_io.h: Add support for using printk for output in tests. This should be followed up by disabling the console driver and other support when the tests are using printk. | |||||
2007-02-11 | 2007-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/check-cpuopts.m4: Check rtems/system.h instead of rtems/score/cpuopts.h. | |||||
2006-12-02 | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: New BUG-REPORT address. | |||||
2006-10-18 | 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8. | |||||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/prog-cxx.m4: Add AC_PROG_CXXCPP. | |||||
* aclocal/version.m4: Bump version to 4.7.99.0. | |||||
* configure.ac: Require autoconf-2.60. Require automake-1.10. | |||||
2006-07-14 | added ChangeLog entries for PR1117/1118/1119/1120 | Thomas Doerfler | 1 | -0/+6 | |
2006-04-19 | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* aclocal/version.m4: Updated to rtems-4.6.99.3. | |||||
2006-04-18 | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
2006-02-01 | 2006-02-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
PR 855/tests * support/include/tmacros.h: Fix typo. | |||||
2005-11-22 | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* aclocal/enable-bare.m4: Remove (Unused). | |||||
2005-11-22 | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+2 | |
* aclocal/env-rtemsbsp.m4: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL. |
