* support/include/tmacros.h: Remove PRItime_t.
* support/include/pritime.h: New.
* Makefile.am: Add support/include/pritime.h
* support/include/test_support.h: Fixed incorrect name in prototype.
* support/include/tmacros.h: Disable the check for dispatch disable
level for SMP tests. Another CPU may be inside RTEMS by the time
these checks are being done which would result in false failures.
* psxtmtests/Makefile.am, psxtmtests/configure.ac,
psxtmtests/psxtmtests_plan.csv: Added nanosleep tests.
* psxtmtests/psxtmnanosleep01/Makefile.am,
psxtmtests/psxtmnanosleep01/init.c,
psxtmtests/psxtmnanosleep01/psxtmnanosleep01.doc,
psxtmtests/psxtmnanosleep02/Makefile.am,
psxtmtests/psxtmnanosleep02/init.c,
psxtmtests/psxtmnanosleep02/psxtmnanosleep02.doc: New files.
* configure.ac, support/include/test_support.h:
* support/src/locked_print.c: New file.
PR 1784
* sptests/spsize/size.c: Split bspsmp.h into two files smp.h and
bspsmp.h
PR 1777/cpukit
* support/include/tmacros.h, tmtests/tm26/task1.c,
tmtests/tm27/task1.c: Consolidated access to
_Thread_Dispatch_disable_level.
* configure.ac: Add fstests.
* aclocal/env-rtemsbsp.m4, aclocal/rtems-top.m4, aclocal/version.m4:
Rename RTEMS_API into _RTEMS_API.
* aclocal/canonical-target-name.m4:
Stop pretending no_cpu* was buildable.
Derive RTEMS_CPU from "$host_cpu".
Error out if "$host" doesn't match "*-*-rtems*".
* support/src/tmtests_support.c:
loop_overhead and end_time are uint32_t's.
* support/src/spin.c, support/src/test_support.c,
support/src/tmtests_empty_function.c, support/src/tmtests_support.c:
Add HAVE_CONFIG_H.
* support/include/tmacros.h: Remove PRIxblksize_t, PRIxblkcnt_t.
* configure.ac: Add initial small set of POSIX Timing Tests.
PR 1708/build:
* aclocal/check-cpuopts.m4: Fix m4-quoting.
* aclocal/check-cpuopts.m4: Add AC_LANG_SOURCE.
* automake/compile.am: Remove clean-local:.
Use CLEANFILES for cleaning up make-exe by-products.
PR 1532/testing
* aclocal/project-root.m4: Add initial tests for untar capabilities.
* support/include/test_support.h, support/src/test_support.c: Add
Allocate_majority_of_heap().
* support/src/tmtests_support.c: Fix warning.
* support/include/test_support.h, support/src/tmtests_empty_function.c:
Add helper so it is easier to write a basic repeated operation
tmtest.
* support/src/tmtests_support.c: New file.
* configure.ac: Remove itron.
* aclocal/version.m4: Bump RTEMS_API to 4.11.
Bump _RTEMS_VERSION to 4.10.99.0.
* support/include/tmacros.h: Remove PRIdoff_t.
* support/include/tmacros.h: Changed check_dispatch_disable_level() to
treat all non-zero values of _Thread_Dispatch_disable_level equally.
* support/include/test_support.h, support/include/tmacros.h,
support/src/test_support.c: Added support functions to spin for a
number of ticks and to spin until the next tick.
* support/src/spin.c: New file.
* support/include/tmacros.h: Use rtems_test_assert() consistently
instead of system assert(). rtems_test_assert() is designed to
integrate into the RTEMS test suite infrastructure.
* support/include/tmacros.h: Add service to check status returned by
POSIX methods which return a pointer which is -1 on error. This
eliminated some casts.
* support/include/tmacros.h: Include rtems/score/thread.h.
Remove _Thread_Dispatch_disable_level.
* support/include/tmacros.h: Add PRIxino_t, PRIdoff_t,
Comment cleanups.
* support/include/tmacros.h: Add PRIxrtems_task_priority,
PRIxrtems_task_priority, PRIxrtems_signal_set.
* support/include/tmacros.h: Add PRIxpthread_t.
* support/include/tmacros.h: Add PRIxrtems_event_set.
(fatal_posix_service_status_errno) Add local "long" var "statx".
* support/include/tmacros.h: Add PRIdThread_Entry_numeric_type.
Add PRIdrtems_task_argument.
* support/include/tmacros.h: Add PRIdWatchdog_Interval.
Add PRIdrtems_interval.
* support/include/tmacros.h: Add PRIdPriority_Control.
Change PRIdrtems_task_priority to using PRIdPriority_Control.
* support/include/tmacros.h: Add PRIdrtems_task_priority.
* support/include/tmacros.h: Add PRIxrtems_id.
* support/include/tmacros.h: Add PRItime_t.
* support/include/tmacros.h (print_time): Use PRIu32 instead of %d.
* support/include/test_support.h: Add missing prototypes.
* support/include/tmacros.h: Move _Thread_Dispatch_disable_level
outside of check_dispatch_disable_level.
* support/src/test_support.c: Add missing prototypes.
* support/include/tmacros.h: Include <inttypes.h>.
Move extern "C".
Let put_name use "int" instead "uint32_t" (Arg to putchar must be int).
* Makefile.am: Add support/include/test_support.h.
* automake/compile.am: Add *.ralf to clean-local.
* aclocal/check-custom-bsp.m4: Fix up AC_REQUIRES.
