* aclocal/canonical-target-name.m4:
Stop pretending no_cpu* was buildable.
Derive RTEMS_CPU from "$host_cpu".
Error out if "$host" doesn't match "*-*-rtems*".
* support/src/tmtests_support.c:
loop_overhead and end_time are uint32_t's.
* support/src/spin.c, support/src/test_support.c,
support/src/tmtests_empty_function.c, support/src/tmtests_support.c:
Add HAVE_CONFIG_H.
* support/include/tmacros.h: Remove PRIxblksize_t, PRIxblkcnt_t.
* configure.ac: Add initial small set of POSIX Timing Tests.
PR 1708/build:
* aclocal/check-cpuopts.m4: Fix m4-quoting.
* aclocal/check-cpuopts.m4: Add AC_LANG_SOURCE.
* automake/compile.am: Remove clean-local:.
Use CLEANFILES for cleaning up make-exe by-products.
PR 1532/testing
* aclocal/project-root.m4: Add initial tests for untar capabilities.
* support/include/test_support.h, support/src/test_support.c: Add
Allocate_majority_of_heap().
* support/src/tmtests_support.c: Fix warning.
* support/include/test_support.h, support/src/tmtests_empty_function.c:
Add helper so it is easier to write a basic repeated operation
tmtest.
* support/src/tmtests_support.c: New file.
* configure.ac: Remove itron.
* aclocal/version.m4: Bump RTEMS_API to 4.11.
Bump _RTEMS_VERSION to 4.10.99.0.
* support/include/tmacros.h: Remove PRIdoff_t.
* support/include/tmacros.h: Changed check_dispatch_disable_level() to
treat all non-zero values of _Thread_Dispatch_disable_level equally.
* support/include/test_support.h, support/include/tmacros.h,
support/src/test_support.c: Added support functions to spin for a
number of ticks and to spin until the next tick.
* support/src/spin.c: New file.
* support/include/tmacros.h: Use rtems_test_assert() consistently
instead of system assert(). rtems_test_assert() is designed to
integrate into the RTEMS test suite infrastructure.
* support/include/tmacros.h: Add service to check status returned by
POSIX methods which return a pointer which is -1 on error. This
eliminated some casts.
* support/include/tmacros.h: Include rtems/score/thread.h.
Remove _Thread_Dispatch_disable_level.
* support/include/tmacros.h: Add PRIxino_t, PRIdoff_t,
Comment cleanups.
* support/include/tmacros.h: Add PRIxrtems_task_priority,
PRIxrtems_task_priority, PRIxrtems_signal_set.
* support/include/tmacros.h: Add PRIxpthread_t.
* support/include/tmacros.h: Add PRIxrtems_event_set.
(fatal_posix_service_status_errno) Add local "long" var "statx".
* support/include/tmacros.h: Add PRIdThread_Entry_numeric_type.
Add PRIdrtems_task_argument.
* support/include/tmacros.h: Add PRIdWatchdog_Interval.
Add PRIdrtems_interval.
* support/include/tmacros.h: Add PRIdPriority_Control.
Change PRIdrtems_task_priority to using PRIdPriority_Control.
* support/include/tmacros.h: Add PRIdrtems_task_priority.
* support/include/tmacros.h: Add PRIxrtems_id.
* support/include/tmacros.h: Add PRItime_t.
* support/include/tmacros.h (print_time): Use PRIu32 instead of %d.
* support/include/test_support.h: Add missing prototypes.
* support/include/tmacros.h: Move _Thread_Dispatch_disable_level
outside of check_dispatch_disable_level.
* support/src/test_support.c: Add missing prototypes.
* support/include/tmacros.h: Include <inttypes.h>.
Move extern "C".
Let put_name use "int" instead "uint32_t" (Arg to putchar must be int).
* Makefile.am: Add support/include/test_support.h.
* automake/compile.am: Add *.ralf to clean-local.
* aclocal/check-custom-bsp.m4: Fix up AC_REQUIRES.
* aclocal/canonical-target-name.m4: Remove RTEMS_HOST (unused).
Remove posix/unix simulator.
* psxtests/psxclock/init.c, psxtests/psxclock/psxclock.scn: Add test
case for nanosleep of a very small delay which mathematically is less
than a clock tick.
* configure.ac: Some POSIX tests exercise functionality which is
enabled when the POSIX threading is disabled. So build this suite all
the time and let the psxtests select the specific tests to build.
* support/include/tmacros.h: Eliminate test routines TICKS_PER_SECOND
and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* support/src/test_support.c: Tinker with longest valid name.
* support/include/buffer_test_io.h: Use printk on AVR by default.
* support/src/tmtests_empty_function.c: Fix warnings.
* aclocal/prog-cc.m4: Preset ac_cv_exeext=.exe for *-rtems*
toolchains.
* aclocal/canonical-target-name.m4: Remove tic4x.
* aclocal/version.m4: Bump RTEMS_API to 4.10.
Bump _RTEMS_VERSION to 4.9.99.0.
