* | 2008-09-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-06 | 1 | -0/+4 |
| | | | | * support/src/test_support.c: Convert to "bool". | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 1 | -0/+4 |
| | | | | * support/src/tmtests_empty_function.c: New file. | ||||
* | 2008-07-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-07-02 | 1 | -0/+5 |
| | | | | | * aclocal/rtems-top.m4: Require AC_DISABLE_OPTION_CHECKING. AC_PREREQ(2.62). | ||||
* | 2008-02-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-02-20 | 1 | -0/+4 |
| | | | | * aclocal/enable-rtemsbsp.m4: s/AC_HELP/AS_HELP/. | ||||
* | 2008-02-04 Jennifer Averett <jennifer.averett@OARcorp.com> | Jennifer Averett | 2008-02-04 | 1 | -0/+4 |
| | | | | * support/include/test_support.h, support/src/test_support.c: New files. | ||||
* | 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-02-01 | 1 | -0/+6 |
| | | | | | | * support/include/tmacros.h: Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a clock_settime case for < 1988. | ||||
* | 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-01-31 | 1 | -0/+4 |
| | | | | * support/include/tmacros.h: Fix put_name to handle unprintable names. | ||||
* | 2008-01-29 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-01-29 | 1 | -0/+5 |
| | | | | | * support/include/tmacros.h: Add new rtems_test_assert() which exits rather than calling fatal error. | ||||
* | 2007-12-17 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-17 | 1 | -0/+4 |
| | | | | * support/include/tmacros.h: Add new helper for POSIX tests. | ||||
* | 2007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-09-21 | 1 | -0/+5 |
| | | | | | * aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0. | ||||
* | 2007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-11 | 1 | -0/+6 |
| | | | | | | * support/include/buffer_test_io.h: Add support for using printk for output in tests. This should be followed up by disabling the console driver and other support when the tests are using printk. | ||||
* | 2007-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-02-11 | 1 | -0/+5 |
| | | | | | * aclocal/check-cpuopts.m4: Check rtems/system.h instead of rtems/score/cpuopts.h. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 1 | -0/+4 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-18 | 1 | -0/+5 |
| | | | | | * aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -0/+4 |
| | | | | * aclocal/prog-cxx.m4: Add AC_PROG_CXXCPP. | ||||
| | | | | * aclocal/version.m4: Bump version to 4.7.99.0. | ||||
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | added ChangeLog entries for PR1117/1118/1119/1120 | Thomas Doerfler | 2006-07-14 | 1 | -0/+6 |
* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-19 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.3. | ||||
* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-18 | 1 | -0/+4 |
* | 2006-02-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-01 | 1 | -0/+5 |
| | | | | | PR 855/tests * support/include/tmacros.h: Fix typo. | ||||
* | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-22 | 1 | -0/+1 |
| | | | | * aclocal/enable-bare.m4: Remove (Unused). | ||||
* | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-22 | 1 | -1/+2 |
| | | | | | | * aclocal/env-rtemsbsp.m4: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL. | ||||
* | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-22 | 1 | -0/+5 |
| | | | | | * configure.ac: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL. | ||||
* | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-22 | 1 | -1/+1 |
| | | | | * automake/compile.am: Remove .obj. | ||||
* | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-22 | 1 | -0/+4 |
| | | | | * automake/compile.am: Remove .coff. | ||||
* | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-13 | 1 | -0/+2 |
| | | | | | * automake/local.am: Remove depend. * automake/host.am: Remove depend. | ||||
| | | | | | * automake/subdirs.am: Remove preinstall, preinstall-recursive. * automake/local.am: Remove preinstall-am. | ||||
| | | | | | * aclocal/env-rtemsbsp.m4: Remove includedir. Remove libdir. Set rtems_testsdir to $libdir/rtems-4.7/tests. | ||||
* | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-13 | 1 | -0/+1 |
| | | | | * configure.ac: Remove AMPOLISH3 (Unused). | ||||
| | | | | * aclocal/env-rtemsbsp.m4: Remove RTEMS_CPU_MODEL. | ||||
* | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-13 | 1 | -0/+4 |
| | | | | | | | * automake/compile.am: Remove LINK_OBJS. Remove LINK_FILES. Remove ARCH. Remove LINK_LIBS. Extend clean-local to catch most temporary files make-exe is creating. | ||||
* | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-13 | 1 | -0/+3 |
| | | | | | | * aclocal/env-rtemsbsp.m4: Remove project_libdir. Remove project_includedir. Add rtems_testsdir. | ||||
| | | | | * aclocal/rtems-top.m4: Remove dirstamp. | ||||
* | 2005-11-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-11 | 1 | -0/+2 |
| | | | | | * Makefile.am: Remove preinstall.am * preinstall.am: Remove. | ||||
* | 2005-11-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-11 | 1 | -0/+4 |
| | | | | * support/.cvsignore: Remove (Revert Joel's yesterday's patch). | ||||
* | 2005-11-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-11-10 | 1 | -0/+4 |
| | | | | * support/.cvsignore: New file. | ||||
* | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 1 | -0/+1 |
| | | | | * Makefile.am: Don't preinstall support/include headers. | ||||
* | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 1 | -0/+4 |
| | | | | * configure.ac: Fix config-variables of conditionally built subdirs. | ||||
* | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 1 | -0/+8 |
| | | | | | | | | * aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-networking.m4, aclocal/check-posix.m4, aclocal/check-tests.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4: Remove (Unused). | ||||
| | | | | * configure.ac: Apply RTEMS_CHECK_CPUOPTS. | ||||
* | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 1 | -0/+2 |
| | | | | | * aclocal/prog-cc.m4: Apply cpukit_root, project_root to set up GCCSPECS. | ||||
| | | | | | * aclocal/check-cpuopts.m4: Apply cpukit_root, project_root to set up temporary CPPFLAGS to compile check cpuopts.h. | ||||
* | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 1 | -0/+3 |
| | | | | | | * aclocal/rtems-top.m4: Add --enable-cpukit-root, --enable-project-root. Remove --with-project-root. Fix --enable-rtems-root. | ||||
* | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 1 | -0/+5 |
| | | | | | * automake/compile.am, aclocal/env-rtemsbsp.m4: Assume PROJECT_ROOT to contain RTEMS_BSP. | ||||
* | Merge-in support/ChangeLog. | Ralf Corsepius | 2005-11-09 | 1 | -215/+214 |
| | | | | | * Makefile.am: Merge-in support/Makefile.am * configure.ac: Add AMPOLISH3. Remove support/. | ||||
* | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 1 | -0/+7 |
| | | | | | | | * aclocal/check-cpuopts.m4: Add config.cache support. * aclocal/check-cxx.m4: Remove CPLUS_LD_LIBS. * automake/compile.am: Eliminate PROJECT_LIB. Remove START_FILE, OBJS from LINK_FILES. | ||||
* | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 1 | -0/+1 |
| | | | | * aclocal/check-cpuopts.m4: New. | ||||
* | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-08 | 1 | -0/+2 |
| | | | | | * automake/compile.am: Remove RTEMS_CPPFLAGS, RTEMS_CFLAGS, RTEMS_CXXFLAGS. |
