* support/include/tmacros.h: Fix put_name to handle unprintable names.
* support/include/tmacros.h: Add new rtems_test_assert() which exits
rather than calling fatal error.
* support/include/tmacros.h: Add new helper for POSIX tests.
* aclocal/version.m4: Bump RTEMS_API to 4.9.
Bump RTEMS_VERSION to 4.8.99.0.
* support/include/buffer_test_io.h: Add support for using printk for
output in tests. This should be followed up by disabling the console
driver and other support when the tests are using printk.
* aclocal/check-cpuopts.m4: Check rtems/system.h instead of
rtems/score/cpuopts.h.
* aclocal/rtems-top.m4: Remove RTEMS_API.
* aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8.
* aclocal/prog-cxx.m4: Add AC_PROG_CXXCPP.
* aclocal/version.m4: Bump version to 4.7.99.0.
* aclocal/version.m4: Updated to rtems-4.6.99.3.
PR 855/tests
* support/include/tmacros.h: Fix typo.
* aclocal/enable-bare.m4: Remove (Unused).
* aclocal/env-rtemsbsp.m4:
Remove RTEMS_ENABLE_BARE,
BARE_CPU_CFLAGS, BARE_CPU_MODEL.
* configure.ac: Remove RTEMS_ENABLE_BARE,
* automake/compile.am: Remove .obj.
* automake/compile.am: Remove .coff.
* automake/local.am: Remove depend.
* automake/host.am: Remove depend.
* automake/subdirs.am: Remove preinstall, preinstall-recursive.
* automake/local.am: Remove preinstall-am.
* aclocal/env-rtemsbsp.m4: Remove includedir. Remove libdir.
Set rtems_testsdir to $libdir/rtems-4.7/tests.
* configure.ac: Remove AMPOLISH3 (Unused).
* aclocal/env-rtemsbsp.m4: Remove RTEMS_CPU_MODEL.
* automake/compile.am: Remove LINK_OBJS. Remove LINK_FILES.
Remove ARCH. Remove LINK_LIBS.
Extend clean-local to catch most temporary files make-exe is
creating.
* aclocal/env-rtemsbsp.m4: Remove project_libdir.
Remove project_includedir.
Add rtems_testsdir.
* aclocal/rtems-top.m4: Remove dirstamp.
* Makefile.am: Remove preinstall.am
* preinstall.am: Remove.
* support/.cvsignore: Remove (Revert Joel's yesterday's patch).
* support/.cvsignore: New file.
* Makefile.am: Don't preinstall support/include headers.
* configure.ac: Fix config-variables of conditionally built subdirs.
* aclocal/check-itron.m4, aclocal/check-multiprocessing.m4,
aclocal/check-networking.m4, aclocal/check-posix.m4,
aclocal/check-tests.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4: Remove (Unused).
* configure.ac: Apply RTEMS_CHECK_CPUOPTS.
* aclocal/prog-cc.m4: Apply cpukit_root, project_root to set up
GCCSPECS.
* aclocal/check-cpuopts.m4: Apply cpukit_root, project_root to set
up temporary CPPFLAGS to compile check cpuopts.h.
* aclocal/rtems-top.m4: Add --enable-cpukit-root,
--enable-project-root. Remove --with-project-root.
Fix --enable-rtems-root.
* automake/compile.am, aclocal/env-rtemsbsp.m4:
Assume PROJECT_ROOT to contain RTEMS_BSP.
* Makefile.am: Merge-in support/Makefile.am
* configure.ac: Add AMPOLISH3. Remove support/.
* aclocal/check-cpuopts.m4: Add config.cache support.
* aclocal/check-cxx.m4: Remove CPLUS_LD_LIBS.
* automake/compile.am: Eliminate PROJECT_LIB.
Remove START_FILE, OBJS from LINK_FILES.
* aclocal/check-cpuopts.m4: New.
* automake/compile.am: Remove RTEMS_CPPFLAGS, RTEMS_CFLAGS,
RTEMS_CXXFLAGS.
* aclocal/gcc-isystem.m4: Remove (Unused).
* aclocal/env-rtemsbsp.m4: Remove GCCSPECS.
* aclocal/prog-cc.m4: Add GCCSPECS. Remove RTEMS_CPPFLAGS.
Remove RTEMS_CFLAGS.
* aclocal/prog-cc.m4: Remove RTEMS_USE_GCC.
Remove RTEMS_GCC_PIPE. Remove RTEMS_GCC_SPECS.
* aclocal/gcc-pipe.m4: Remove (Unused).
* aclocal/gcc-specs.m4: Remove (Unused).
* aclocal/env-rtemsbsp.m4: Merge RTEMS_BSP_SPECS and
GCC_SPECS into GCCSPECS.
* automake/compile.am: Remove RTEMS_BSP_SPECS, GCC_SPECS.
Don't manually set up GCCSPEC (Now setup from inside configure).
Remove RTEMS_RELLDFLAGS (Used).
* automake/compile.am: Remove CCAS support.
* aclocal/multilib.m4: Remove (Unused).
* aclocal/check-multiprocessing.m4: Don't require
RTEMS_ENABLE_MULTILIB.
* aclocal/env-rtemsbsp.m4: Don't provide MULTILIB conditional.
