path: root/spec (follow)
* build: Add RTEMS_GCOV_COVERAGE optionSebastian Huber2022-07-049-2/+112
| | | | Update #4670.
* gcov: Add wrapper to dump the gcov infoSebastian Huber2022-07-041-0/+2
| | | | Update #4670.
* gcov: Add functions to dump the gcov informationSebastian Huber2022-07-042-0/+4
| | | | Update #4670.
* gcov: Add fork(), etc. gcov wrappersSebastian Huber2022-07-041-0/+1
| | | | | | | | The compiler wraps fork(), etc. system calls if coverage generation is enabled. These functions must be provided by the system. For RTEMS, they just return an error status. Update #4670.
* build: Allow separate optimization flagsSebastian Huber2022-07-0412-19/+92
| | | | | | | | Allow separate optimization flags for the BSP, cpukit, and tests. For example, the BSP and cpukit may be built without optimization if coverage instrumentation is enabled, however, the tests may still use optimization. Update #4670.
* build: Fix optimization flags definition orderSebastian Huber2022-07-0464-128/+128
| | | | | | OPTIMIZATION_FLAGS must be defined before /build/bsp/bspopts is processed. Update #4670.
* build: Add cppflags, cflags, cxxflags to groupsSebastian Huber2022-07-0470-1/+211
| | | | | | | Propagate the group defined cppflags, cflags, and cxxflags from parent groups to child items through the build item context. Update #4670.
* build: Move BSP_INCLUDES splitSebastian Huber2022-07-041-0/+1
| | | | The goal is to let the build items define as much as possible.
* bsp/stm32h7: Exclude some testsSebastian Huber2022-06-241-0/+2
* bsp/rtl22xx: Exclude exit03Sebastian Huber2022-06-241-0/+1
* tstsmallmem: Exclude exit03 and tftpfsSebastian Huber2022-06-241-0/+2
* TFTPFS: Add testsFrank Kühndel2022-06-212-0/+27
| | | | Update #4666.
* TFTPFS: Implement block and window size optionsFrank Kühndel2022-06-211-1/+2
| | | | | | | | | | | | | | | | | | | | | The original file cpukit/libfs/src/ftpfs/tftpDriver.c is split into two: tftpfs.c - This file contains the code from tftpDriver.c related to file system operations such as mount(), open(), read(), and so on. tftpDriver.c - In the original file remains only the code related to networking. This code implements the Trivial File Transfer Protocol (TFTP). Moreover, the code is extended to support * RFC 2347 TFTP Option Extension * RFC 2348 TFTP Blocksize Option * RFC 7440 TFTP Windowsize Option Update #4666.
* bsps/versal: Support a 64bit RAM baseChris Johns2022-06-161-1/+1
| | | | Set the constraint to be 64bits to allow the complete address range.
* bsps/atsam: Fix type of options (part 2)Christian Mauderer2022-06-142-2/+4
| | | | | | | The patch "bsps/atsam: Fix type of options" missed to adapt some parts of the yml. With that a custom value works well. But if no value is set, configure doesn't fall back to the default value but instead just causes an error. This patch fixes that.
* bsps/stm32h7: remove external memory initialization from nucleo-h743zi BSPKarel Gardas2022-06-101-1/+0
| | | | | | | Nucleo board does not provide any external memory so code does not have any function here anyway. Sponsored-By: Precidata
* bsps/stm32h7: move BSP start hooks into boards subdirectoriesKarel Gardas2022-06-107-0/+7
| | | | | | | The idea here is to prepare for better per-board specialization of the hooks function code. Sponsored-By: Precidata
* bsps/arm: fix installation of core_cm4.hKarel Gardas2022-06-101-0/+1
* bsps/imx: Enable clock of ETH2Christian Mauderer2022-06-091-0/+1
* testsuite/libtests: Add exit03 to test exit() with C++Chris Johns2022-06-092-0/+22
| | | | Updates #4661
* bsps/atsam: Fix type of optionsChristian Mauderer2022-06-072-4/+4
| | | | | | ATSAM_CONSOLE_DEVICE_INDEX and ATSAM_CONSOLE_DEVICE_TYPE have to be integers like suggested by their description. Otherwise it's not possible to select (for example) USART2 as console device.
* bsps/stm32h7: set SDRAM 1 size to 0 by default on nucleo-h743zi BSPKarel Gardas2022-06-021-0/+1
| | | | | | | Nucleo does not have any SDRAM, so 0 size is the only possible right choice here. Sponsored-By: Precidata
* bsps/stm32h7: set default linkage to flash for nucleo-h743zi BSPKarel Gardas2022-06-021-0/+1
| | | | | | | Nucleo does not have any SDRAM so default linkage to SDRAM does not make any sense here. Sponsored-By: Precidata
* bsps/stm32h7: set default printk instance on nucleo-h743zi BSP to USART3Karel Gardas2022-06-021-1/+4
| | | | | | | | This is the default configuration of the board out of the box. Any other possible/supported configuration requires soldering, so definitely not out of the box experience. Sponsored-By: Precidata
* bsps/stm32h7: add stm32h747i-disco-m4 BSP variantKarel Gardas2022-06-0220-0/+43
| | | | | | | | | This patch adds stm32h747i-disco-m4 BSP variant and puts it in sync with the stm32h747i-disco BSP variant hardware support. That means, only USART 1, 2 and UART 8 are enabled. Also SDRAM 2 is set to 32MB, SDRAM 1 size is set to 0. Sponsored-By: Precidata
* bsps/stm32h7: set default SDRAM x sizes on stm32h747i-disco BSPKarel Gardas2022-06-012-0/+2
| | | | | | | | | This means: SDRAM 1: 0 SDRAM 2: 32 MB Sponsored-By: Precidata
* bsps/stm32h7: disable all unsupported U(S)ARTs on stm32h747i-disco BSPKarel Gardas2022-06-017-0/+7
| | | | | | | | This patch disables all U(S)ARTs which are not supported by the board itself and its provided connectors. That means only USART1 and 2 and UART8 are enabled. Sponsored-By: Precidata
* bsps/stm32h7: add configuration and enable build of stm32h747i-disco BSPKarel Gardas2022-06-018-0/+33
* bsps/stm32h7: set default SDRAM x sizes on stm32h757i-eval-m4 BSPKarel Gardas2022-06-012-0/+2
* bsps/stm32h7: disable all U(S)ARTs except USART1 on stm32h757i-eval-m4 BSPKarel Gardas2022-06-019-0/+9
| | | | | | | This patch disables all U(S)ARTs which are not supported by the board itself and its provided connectors. Sponsored-By: Precidata
* bsps/stm32h7: add configuration and enable build of stm32h757i-eval-m4 BSPKarel Gardas2022-06-0111-3/+66
| | | | | | | | | | | | | | | | This is minimalist configuration for the stm32h757i-eval-m4 BSP provided here. The only general enhancement worth mention is a flash origin address configuration which is needed for simplification as M4 core boots from second flash bank which starts at 0x8100000 by default. The boot address of the core may be changed by using STM32CubeProgrammer. If done so then also BSP configuration needs to be changed accordingly. As the BSP variant is running on M4 core, there is also more configuration changes required here. E.g. boot core and ABI (compilation flags) in comparison with stm32h757i-eval BSP. On the other hand, C code is shared completely with this BSP variant. Sponsored-By: Precidata
* bsps/stm32h7: move cache implementation from obj to BSPs own yml fileKarel Gardas2022-06-015-1/+4
| | | | | | | This is done in preparation for future Cortex-M4 based BSP variants which do not provide cache at all. Sponsored-By: Precidata
* bsps/stm32h7: set default SDRAM x sizes on stm32h757i-eval BSPKarel Gardas2022-05-272-1/+5
* bsps/stm32h7: provide linkcmds for SRAM, FLASH_SDRAM and SRAM_SDRAM linkingKarel Gardas2022-05-275-2/+156
* bsps/stm32h7: add and enable test set exclusion for stm32h757i-eval BSPKarel Gardas2022-05-272-0/+21
* bsps/stm32h7: disable all U(S)ARTs except USART1 on stm32h757i-eval BSPKarel Gardas2022-05-279-2/+16
* bsps/stm32h7: add configuration and enable build of stm32h757i-eval BSPKarel Gardas2022-05-277-0/+54
| | | | | | | | | | This is minimalist configuration for the stm32h757i-eval BSP provided here. The only general enhancement worth mention is boot core configuration which is needed here as this is the first dual-core board supported by stm32h7 BSP family and we need to choose boot core in order to get C files compiling well. Sponsored-By: Precidata
* testsuites/sptests: Add sppps01 testGabriel Moyano2022-05-232-0/+21
| | | | Update #2349.
* bsp/stm32h7: copy system files to nucleo-h743zi board directoryKarel Gardas2022-05-161-5/+5
| | | | | | Also adjust BSP spec file to make it buildable with board files. Sponsored-By: Precidata
* bsp/stm32h7: copy system files to stm32h743i-eval board directoryKarel Gardas2022-05-161-5/+5
* bsp/stm32h7: copy system files to stm32h7b3i-dk board directoryKarel Gardas2022-05-161-5/+5
* bsp/stm32h7: move compilation of system files to BSPs spec. filesKarel Gardas2022-05-164-8/+18
| | | | | | The patch is done in preparation for stm32h7 BSP tree refactoring. Sponsored-By: Precidata
* build: Check for psxtests prerequisitesSebastian Huber2022-05-055-4/+10
| | | | Close #4645.
* build: Remove obsolete test excludesSebastian Huber2022-04-0613-52/+0
* bsps: Add <dev/irq/arm-gicv3.h>Sebastian Huber2022-04-062-0/+2
| | | | | | | | Separate the Interrupt Manager implementation from the generic Arm GICv3 support. Move parts of the Arm GICv3 support into a new header file. This helps to support systems with a clustered structure in which multiple GICv3 instances are present. For example, two clusters of two Cortex-R52 cores where each cluster has a dedicated GICv3 instance.
* unit: Test red-black treesSebastian Huber2022-04-061-0/+1
* unit: Add test for misaligned builtin memcpy()Sebastian Huber2022-04-061-0/+1
* unit: Add a unit test suiteSebastian Huber2022-04-065-0/+60
* bsp/stm32h7: Disable some tests for a variantSebastian Huber2022-04-061-0/+2
| | | | Making this BSP a small memory target is a bit coarse and could be improved.
* bsps/stm32h7: link to flash on STM32H7B3I-DKKarel Gardas2022-04-061-1/+4
| | | | | The patch is needed due to smaller SRAM and completely disabled SDRAM on the BSP variant.
