- Move the heap sbrk code into a separate routnine.
- Update heap and workspace greedy allocators to use the common
sbrk greedy support.
Closes #3982
Update #4230.
Rename _Nios2_ISR_Dispatch_with_shadow_non_preemptive() in
_Nios2_ISR_Dispatch_with_shadow_register_set(). Remove
_Nios2_ISR_Dispatch_with_shadow_preemptive().
Sort alphabetically.
GCC 11 uses DWARF 5 by default.
Move the Freescale EDMA driver to it's own object and build it only for
the BSP that is currently using it.
This allows an application to get the registers of the LPSPI. That is
usefull for applications that want to use DMA for a very specialized and
highly optimized communication.
Update #4180
Note: The changes have been done with portability in mind. The driver
should (in theory) be able to replace the original one in the MPC BSPs
too. For full compatibility an adaption layer and especially a test
would be necessary. Because both are missing, don't integrate it into
the MPC BSP now.
Update #4180
This allows applications to individually provide configuration
structures.
Update #4209.
structures.
Update #4209.
This commit adds a basic test that tests all the implemented
RTEMS OFW functions.
RTEMS OFW is a FDT only implementation of the OpenFirmWare
interface. This API is created to be compatible with FreeBSD
OpenFirmWare interface. The main intention is to make
porting of FreeBSD drivers to RTEMS easier.
Most functions implemented have an direct one-one mapping
with the original OFW API and some extra auxiliary functions
were implemented to make working with device trees easier in
RTEMS.
Update #3784
This BSP supports the Arm Fixed Virtual Platform. Only the Cortex-R52
processor configuration is supported by the BSP. It should be easy to
add support for other variants if needed.
Update #4202.
This avoids a function call overhead in the interrupt dispatching.
Update #4202.
Set the VBAR to the vector table in the start section before
bsp_start_hook_0() is called to earlier handle exceptions in RTEMS.
Set the VBAR to the normal vector table in start.S for the main
processor. Secondary processors set it in bsp_start_hook_0().
Update #4202.
Update #4202.
When moving the headers from the imx BSP to the shared area, the wrong
directory has been selected. This patch fixes that problem.
Update #4180
This allows simpler creation of own dts files for custom boards.
Update #4180
This adds some commands that are usefull for debugging simple serial
interfaces.
Even if they are a complete re-implementation, the i2c* commands use a
simmilar call like the Linux i2c tools.
- Disabled by default
- Enable using ARM_MMU_USE_SMALL_PAGES option
Close 4192.
Clarify documentation.
Update #4202.
Update #4202.
Update #4202.
Currently, zynq-uart code is always built and has some requirements for
BSPs that use it. Instead of making all BSPs satisfy that requirement or
working around it by setting defaults, this moves the zynq-uart code
into its own spec build object so it can be included if needed.
The option for defining the console minor should be an integer, not a
boolean.
This adds a BSP family that runs on the Xilinx Ultrascale+ MPSOC
(ZynqMP) family of chips. It is configured to be usable on the Qemu
ZCU102 machine definition and should be almost trivially portable to
ZynqMP development boards and custom hardware. It is also configured to
be usable with libbsd.
This moves the ARM GICv2 driver to bsps/shared to be usable by AArch64
code.
This moves the zynq-uart driver from bsps/arm/shared to bsps/shared to
accomodate use by AArch64 BSPs.
In order to better support applications which use the new
rtems_task_construct() directive add the
CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If
this option is specified, then the Classic API initialization task is
constructed with rtems_task_construct().
Update #4181.
Replace a runtime check with a compile time assertion. This makes the
INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL obsolete.
Update #4181.
The spintrcritical03-05 and psx12 tests are known to fail on Qemu when
the host system is heavily loaded. A single run of Qemu per core
during a testsuite run tends to yield positive results, but any
additional load on a system will result in test failures.
This patch also applies the correct expected test state for intermittent
failures so that those tests will still build.
The SUBALIGN(4) required on rtemsroset and rtemsrwset for ILP32 builds
was previously present on LP64 builds and causes no issues within RTEMS,
but causes relocation/alignment issues when building libbsd. This
restricts those alignment changes to ILP32 builds.
These files are required for libbsd to build against the AArch64 A53
BSPs.
Update #4180
Modify the MPU functions of the stm32h7 BSP to be table based and
available for all ARMV7M BSPs.
Update #4180
Update #4180
Update #4180
Replace runtime checks with compile time assertions. This makes the
INTERNAL_ERROR_BAD_STACK_HOOK obsolete.
Share a default test suite with ts-validation-0.
