Sponsored-By: Precidata
This patch disables all U(S)ARTs which are not supported by the board
itself and its provided connectors.
This is minimalist configuration for the stm32h757i-eval BSP provided
here. The only general enhancement worth mention is boot core
configuration which is needed here as this is the first dual-core board
supported by stm32h7 BSP family and we need to choose boot core in order
to get C files compiling well.
Update #2349.
Also adjust BSP spec file to make it buildable with board files.
The patch is done in preparation for stm32h7 BSP tree refactoring.
Close #4645.
Separate the Interrupt Manager implementation from the generic Arm GICv3
support. Move parts of the Arm GICv3 support into a new header file. This
helps to support systems with a clustered structure in which multiple GICv3
instances are present. For example, two clusters of two Cortex-R52 cores where
each cluster has a dedicated GICv3 instance.
Making this BSP a small memory target is a bit coarse and could be improved.
The patch is needed due to smaller SRAM and completely disabled
SDRAM on the BSP variant.
Caveat: SDRAM 1 is completely disabled for now.
function
Make the task configuration reusable.
Update #3716.
Add SMP-specifc SMP_FATAL_MULTITASKING_START_ON_NOT_ONLINE_PROCESSOR
fatal error. This fatal error helps to diagnose a broken SMP startup
sequence. Without this error a context switch using the NULL pointer
for the thread control block happens which may be difficult to debug.
The test source code is generated from specification items
by the "./spec2modules.py" script contained in the
git://git.rtems.org/rtems-central.git Git repository.
Please read the "How-To" section in the "Software Requirements Engineering"
chapter of the RTEMS Software Engineering manual to get more information about
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
