Update #4677.
Dirty or zero also the part of the .noinit section used by RTEMS.
Close #4678.
Use the existing WRITE_SR() abstraction to access the interrupt group 0 and 1
enable registers. This fixes the build for the AArch32 target.
Add BSP options which define the initial values of CPU Interface registers.
Update #3716.
Update #3716.
There were two bugs with MMU page use that were partially hiding each
other. The linker script page table section was 4x the size it needed to
be and the page table allocation routine was allocating pages PTRSIZE
times larger than it needed to. On ILP32, this resulted in incorrect but
functional allocation. On LP64, this resulted in allocation failures
earlier than expected.
Update #4670.
Update #4670.
Update #4670.
The compiler wraps fork(), etc. system calls if coverage generation is enabled.
These functions must be provided by the system. For RTEMS, they just return an
error status.
Update #4670.
Allow separate optimization flags for the BSP, cpukit, and tests. For example,
the BSP and cpukit may be built without optimization if coverage
instrumentation is enabled, however, the tests may still use optimization.
Update #4670.
OPTIMIZATION_FLAGS must be defined before /build/bsp/bspopts is processed.
Update #4670.
Propagate the group defined cppflags, cflags, and cxxflags from parent groups
to child items through the build item context.
Update #4670.
The goal is to let the build items define as much as possible.
Update #4666.
The original file cpukit/libfs/src/ftpfs/tftpDriver.c
is split into two:
tftpfs.c - This file contains the code from tftpDriver.c
related to file system operations such as mount(),
open(), read(), and so on.
tftpDriver.c - In the original file remains only the code related
to networking. This code implements the Trivial
File Transfer Protocol (TFTP).
Moreover, the code is extended to support
* RFC 2347 TFTP Option Extension
* RFC 2348 TFTP Blocksize Option
* RFC 7440 TFTP Windowsize Option
Update #4666.
Set the constraint to be 64bits to allow the complete address range.
The patch "bsps/atsam: Fix type of options" missed to adapt some parts
of the yml. With that a custom value works well. But if no value is set,
configure doesn't fall back to the default value but instead just causes
an error. This patch fixes that.
Nucleo board does not provide any external memory so code does not have
any function here anyway.
Sponsored-By: Precidata
The idea here is to prepare for better per-board specialization
of the hooks function code.
Updates #4661
ATSAM_CONSOLE_DEVICE_INDEX and ATSAM_CONSOLE_DEVICE_TYPE have to be
integers like suggested by their description. Otherwise it's not
possible to select (for example) USART2 as console device.
Nucleo does not have any SDRAM, so 0 size is the only possible right
choice here.
Nucleo does not have any SDRAM so default linkage to SDRAM does not make
any sense here.
This is the default configuration of the board out of the box.
Any other possible/supported configuration requires soldering,
so definitely not out of the box experience.
This patch adds stm32h747i-disco-m4 BSP variant and puts it in sync
with the stm32h747i-disco BSP variant hardware support. That means,
only USART 1, 2 and UART 8 are enabled. Also SDRAM 2 is set to 32MB,
SDRAM 1 size is set to 0.
This means:
SDRAM 1: 0
SDRAM 2: 32 MB
This patch disables all U(S)ARTs which are not supported by the board
itself and its provided connectors. That means only USART1 and 2
and UART8 are enabled.
This means:
SDRAM 1: 0
SDRAM 2: 32 MB
This is minimalist configuration for the stm32h757i-eval-m4 BSP provided
here. The only general enhancement worth mention is a flash origin address
configuration which is needed for simplification as M4 core boots
from second flash bank which starts at 0x8100000 by default. The boot
address of the core may be changed by using STM32CubeProgrammer. If done
so then also BSP configuration needs to be changed accordingly.
As the BSP variant is running on M4 core, there is also more configuration
changes required here. E.g. boot core and ABI (compilation flags)
in comparison with stm32h757i-eval BSP. On the other hand, C code is shared
completely with this BSP variant.
This is done in preparation for future Cortex-M4 based BSP variants
which do not provide cache at all.
This means:
SDRAM 1: 0
SDRAM 2: 32 MB
This is minimalist configuration for the stm32h757i-eval BSP provided
here. The only general enhancement worth mention is boot core
configuration which is needed here as this is the first dual-core board
supported by stm32h7 BSP family and we need to choose boot core in order
to get C files compiling well.
Update #2349.
Also adjust BSP spec file to make it buildable with board files.
The patch is done in preparation for stm32h7 BSP tree refactoring.
Close #4645.
