path: root/spec/build (follow)
* testsuites: Wrap putcharAlex White2021-09-1612-0/+12
| | | | The linker flag to wrap putchar was lost in translation from make to waf.
* build: Remove invalid attributesSebastian Huber2021-09-142-2/+0
* bsps/arm: Fix ABI flags for Cortex-M4Sebastian Huber2021-09-142-3/+5
| | | | Close #4504.
* bsps/zynqmp: Added I2C support for ZynqMPStephen Clark2021-09-095-0/+87
| | | | Added I2C drivers for ZynqMP and updated build system accordingly.
* bsps/zynq: Moved general i2c files to shared directoriesStephen Clark2021-09-091-3/+3
| | | | | Certain files related to the Zynq BSP's I2C driver are useable by the ZynqMP BSP as well. Moved these files to shared directory in anticipation of I2C support for ZynqMP.
* score: Split up rbtreenext.cSebastian Huber2021-09-061-0/+3
| | | | | | | | | | Split up rbtreenext.c since only _RBTree_Minimum() is used by the operating system core services (thread queues and the EDF scheduler). Change license to BSD-2-Clause according to file history and re-licensing agreement. Update #3053.
* score: Add _TOD_Is_valid_new_time_of_day()Sebastian Huber2021-09-061-0/+1
| | | | | | Move the TOD validation to the callers of _TOD_Set(). This avoids dead code in case only rtems_clock_set() is used in an application because rtems_clock_set() always calls _TOD_Set() with a valid time of day.
* score: Remove TOD_TICKS_PER_SECOND_method()Sebastian Huber2021-09-061-1/+0
| | | | Use _Watchdog_Ticks_per_second instead.
* score: Move _Thread_Dispatch()Sebastian Huber2021-09-031-0/+1
| | | | | | | | | | | | The _Thread_Dispatch() function was customized over time and now the work is done by _Thread_Do_dispatch() and specialized wrappers. The plain _Thread_Dispatch() is now only used in some CPU ports. Move it to a separate file to avoid dead code in the general. Change license to BSD-2-Clause according to file history and re-licensing agreement. Update #3053.
* confstr() support for RTEMSEshan dhawan2021-08-183-0/+23
| | | | | | | | Closes #3373 confstr() style update Signed-off-by: Eshan Dhawan <eshandhawan51@gmail.com>
* build: Merge default-by-family into by-variantSebastian Huber2021-08-18761-764/+1
| | | | | | | Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468.
* bsps: Move optfdt* files to shared parent directorypranav2021-08-0924-246/+26
* score: Split SMP multicast action moduleSebastian Huber2021-07-291-0/+3
| | | | | Split up the SMP multicast action module since the use of the SMP multicast action variants depend on the architecture and BSP.
* score: Move per-CPU jobs supportSebastian Huber2021-07-281-2/+2
| | | | Add percpujobs.c to contain the per-CPU jobs implementation.
* validation: Test rtems_interrupt_handler_iterate()Sebastian Huber2021-07-261-0/+1
| | | | Update #3269.
* validation: Test rtems_interrupt_set_affinity()Sebastian Huber2021-07-261-0/+1
| | | | Update #3269.
* validation: Test rtems_interrupt_get_affinity()Sebastian Huber2021-07-261-0/+1
| | | | Update #3269.
* validation: Test rtems_interrupt_raise_on()Sebastian Huber2021-07-261-0/+1
| | | | Update #3269.
* validation: Test rtems_interrupt_is_pending()Sebastian Huber2021-07-261-0/+1
| | | | Update #3269.
* validation: Test rtems_interrupt_clear()Sebastian Huber2021-07-261-0/+1
| | | | Update #3269.
* validation: Test rtems_interrupt_raise()Sebastian Huber2021-07-261-0/+1
| | | | Update #3269.
* validation: Test rtems_interrupt_entry_remove()Sebastian Huber2021-07-261-0/+1
| | | | Update #3269.
* validation: Test rtems_interrupt_entry_install()Sebastian Huber2021-07-261-0/+1
| | | | Update #3269.
* validation: Test rtems_interrupt_vector_disable()Sebastian Huber2021-07-261-0/+1
| | | | Update #3269.
* validation: Test rtems_interrupt_vector_enable()Sebastian Huber2021-07-261-0/+1
| | | | Update #3269.
* validation: rtems_interrupt_vector_is_enabled()Sebastian Huber2021-07-261-0/+1
| | | | Update #3269.
* validation: Test rtems_interrupt_get_attributes()Sebastian Huber2021-07-261-0/+1
| | | | Update #3269.
* validation: HasInterruptVectorEntriesInstalled()Sebastian Huber2021-07-261-0/+1
| | | | Update #3269.
* validation: Add CallWithinISR()Sebastian Huber2021-07-261-0/+1
| | | | Update #3269.
* bsps/irq: Add rtems_interrupt_entry_install()Sebastian Huber2021-07-264-9/+8
| | | | | | | | | | | | | | | | | | | Add rtems_interrupt_entry_remove(). Split up irq-generic.c into several files. In particular, place all functions which use dynamic memory into their own file. Add optional macros to let the BSP customize the vector installation after installing the first entry and the vector removal before removing the last entry: * bsp_interrupt_vector_install() * bsp_interrupt_vector_remove() Use these new customization options in the m68k/genmcf548x BSP so re-use the generic interrupt controller support. Update #3269.
* bsps/irq: Add rtems_interrupt_raise()Sebastian Huber2021-07-263-0/+3
| | | | | | | | | Add rtems_interrupt_raise_on() and rtems_interrupt_clear(). Add a default implementation which just returns RTEMS_UNSATISFIED for valid parameters. Update #3269.
* rtems: Add rtems_interrupt_vector_enable()Sebastian Huber2021-07-263-0/+3
| | | | | | Add rtems_interrupt_vector_disable(). Update #3269.
* bsps/irq: Move handler iterate to separate fileSebastian Huber2021-07-263-0/+3
| | | | Update #3269.
* bsps/irq: Move get/set affinity to separate fileSebastian Huber2021-07-263-0/+3
| | | | Update #3269.
* build: Remove superfluous library from rcxx01Sebastian Huber2021-07-261-1/+0
* Fixes for TMS570 BSPRobin Mueller2021-07-201-1/+1
| | | | | | | | | When compiling the lwIP port for the TMS570, there were issues with the BSP. Headers are expected in a folder named ti_herc which did not exist. This fixes the issue. Furthermore, there were multiple warnings about define redefinitions. This was fixed as well.
* STM32H7 ethernet pin correctionsRobin Mueller2021-07-203-0/+44
| | | | | | | | | | These patches were submitted a few months ago, but it was found out that the default-by-family: [] were missing in the GPIO .yml lines. This was fixed in this patch. This patch accounts for different pins for the ETH peripheral on STM32H7 devices. For example, the Nucleo H743ZI has slightly different pins than other STM32H7 boards.
* build: Add missing default-by-familySebastian Huber2021-07-152-0/+2
| | | | Update #4468.
* spcoverage: Remove test programSebastian Huber2021-07-152-21/+0
| | | | | This program contained an optional test case. It was enabled by the RTEMS_COVERAGE define. The functions under test are not implemented by RTEMS.
* build: Fix the motorola_powerpc default baudrateChris Johns2021-07-151-2/+4
* build: Use BSP family for optionsChris Johns2021-07-15771-0/+771
| | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468
* build: Add option to customize the LINKFLAGSSebastian Huber2021-07-063-1/+19
* bsps/imxrt: Simplify linkcmds and make it flexibleChristian Mauderer2021-07-0212-67/+96
| | | | | | | | | Calling the memory FLASH and EXTRAM instead of FLEXSPI and SDRAM makes it simpler to support other types of external RAM. This patch also removes some of the calculations and improves names and documentation to avoid pitfalls. It removes a unnecessary memory definition. Update #4180
* bsps/imxrt: Allow different ARM PLL settingChristian Mauderer2021-07-021-0/+1
| | | | Update #4180
* Revert "bsps/zynqmp: Allow any or all CGEMs to be enabled"Kinsey Moore2021-07-015-72/+0
| | | | | | | This reverts commit 10041a4cfc00d5f6876d3d6cfc30c23347b4cf42. This type of configuration does not belong in RTEMS and is better constrained to libbsd where the defines are actually being used.
* spec/aarch64: fix abi flags for xilinx_versal_ilp32_vck190Gedare Bloom2021-06-291-0/+1
* bsps/zynqmp: Allow any or all CGEMs to be enabledKinsey Moore2021-06-285-0/+72
| | | | | | | Provide the options necessary to enable any combination of CGEM ethernet interfaces in LibBSD. The default is still CGEM3, so this should continue to operate as expected on typical Zynq Ultrascale+ MPSoC development hardware.
* bsps/aarch64: replace boot options with asm switch codeGedare Bloom2021-06-244-22/+0
* bsps/aarch64: add non-secure mode and versal supportGedare Bloom2021-06-249-6/+68
* bsps/aarch64: add physical secure timerGedare Bloom2021-06-242-0/+33
