path: root/spec/build (follow)
* validation: Add test case support functionsSebastian Huber2021-03-232-0/+2
* bsp/beagle: Ported Beagle pinmux driver to RTEMSG S Niteesh Babu2021-03-211-0/+6
| | | | | | | | | | The following files have been ported 1) ti_pinmux.c 2) ti_pinmux.h 3) am335x_scm_padconf.c 4) am335x_scm_padconf.h Update #3784
* bsps/beagle: Added SOC detection using FDTG S Niteesh Babu2021-03-211-0/+1
| | | | | Detects the SOC type using FDT and also replaces the ti_cpuid.h header in FreeBSD with custom one.
* build: Add test exclude for arm/lpc2362Sebastian Huber2021-03-191-0/+1
* validation: Task create/constructSebastian Huber2021-03-161-0/+2
| | | | | Run the task create/construct tests also on validation test suite 1 which has exactly one processor configured.
* Test suite for FTW.H methodsEshan dhawan2021-03-112-0/+36
| | | | Signed-off-by: Eshan Dhawan <eshandhawan51@gmail.com>
* leon,tn-0018: work around GRLIB-TN-0018 errataDaniel Hellstrom2021-03-111-0/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Overview ======== The errata is worked around in the kernel without requiring toolchain modifications. It is triggered the JMPL/RETT return from trap instruction sequence never generated by the compiler and. There are also other conditions that must must be true to trigger the errata, for example the instruction that the trap returns to has to be a JMPL instruction. The errata can only be triggered if certain data is corrected by ECC (inflicted by radiation), thus it can not be triggered under normal operation. For more information see: www.gaisler.com/notes Affected RTEMS target BSPs: * GR712RC * UT699 * UT700/699E The work around is enabled by defining __FIX_LEON3_TN0018 at build time. After applying the following GCC patch, GCC will set the define when compiling for an affected multilib: * GR712RC (-mcpu=leon3 -mfix-gr712rc) * UT700/UT699E (-mpcu=leon3 -mfix-ut700) * UT699 (-mcpu=leon -mfix-ut699) When building for another multilib and TN0018 is still required, it is possible to enable it on the RTEMS kernel configure line using the TARGET_CFLAGS (-D__FIX_LEON3FT_TN0018) or other by other means. The following GCC patch sets __FIX_LEON3FT_TN0018 for the affected RTEMS multilibs: --------- diff --git a/gcc/config/sparc/rtemself.h b/gcc/config/sparc/rtemself.h index 6570590..ddec98c 100644 --- a/gcc/config/sparc/rtemself.h +++ b/gcc/config/sparc/rtemself.h @@ -33,6 +33,8 @@ builtin_assert ("system=rtems"); \ if (sparc_fix_b2bst) \ builtin_define ("__FIX_LEON3FT_B2BST"); \ + if (sparc_fix_gr712rc || sparc_fix_ut700 || sparc_fix_ut699) \ + builtin_define ("__FIX_LEON3FT_TN0018"); \ } \ while (0) --------- Workaround Implementation ========================= In general there are two approaches that the workaround uses: A) avoid ECC restarting the RETT instruction B) avoid returning from trap to a JMPL instruction Where A) comes at a higher performance cost than B), so B) is used where posssible. B) can be achived for certain returns from trap handlers if trap entry is controlled by assembly, such as system calls. A) A special JMPL/RETT sequence where instruction cache is disabled temporarily to avoid RETT containing ECC errors, and reading of RETT source registers to "clean" them from incorrect ECC just before RETT is executed. B) The work around prevents JMPL after system calls (TA instruction) and modifies assembly code on return from traps jumping back to application code. Note that for some traps the trapped instruction is always re-executed and can therefore not trigger the errata, for example the SAVE instruction causing window overflow or an float instruction causing FPU disabled trap. RTEMS SPARC traps workaround implementation: NAME NOTE TRAP COMMENT * window overflow 1 - 0x05 always returns to a SAVE * window underflow 1 - 0x06 always returns to a RESTORE * interrupt traps 2 - 0x10..1f special rett sequence workaround * syscall 3 - 0x80 shutdown system - never returns * ABI flush windows 2 - 0x83 special rett sequence workaround * syscall_irqdis 4 - 0x89 * syscall_irqen 4 - 0x8A * syscall_irqdis_fp 1 - 0x8B always jumps back to FP instruction * syscall_lazy_fp_switch 5 - 0x04 A) jumps back to FP instruction, or to B) _Internal_error() starting with SAVE Notes: 1) no workaround needed because trap always returns to non-JMPL instruction 2) workaround implemented by special rett sequence 3) no workaround needed because system call never returns 4) workaround implemented by inserting NOP in system call generation. Thus fall into 1) when workaround is enabled and no trap handler fix needed. 5) trap handler branches into both 1) and returning to _Internal_error() which starts with a SAVE and besides since it shuts down the system that RETT should never be in cache (only executed once) so fix not necessary in this case. Any custom trap handlers may also have to be updated. To simplify that, helper work around assembly code in macros are available in a separate include file <libcpu/grlib-tn-0018.h>. Close #4155.
* leon3: avoid dependency on apbuart/timer driverDaniel Hellstrom2021-03-111-0/+1
| | | | | | | Moves drvmgr_drivers[] from amba.c to a separate file in order to avoid the dependecy on APBUART/GPTIMER drivers. This has an effect when user configured not to use timer or uart in their project.
* leon,grcan: split out GRCAN non-FD specific support in separate fileDaniel Hellstrom2021-03-111-0/+1
| | | | Close #4324.
* leon,grcanfd: split out GRCANFD specific support in separate fileDaniel Hellstrom2021-03-111-0/+1
| | | | Update #4324.
* leon,can: introduce common CAN baud-rate calculation functionDaniel Hellstrom2021-03-111-0/+2
| | | | | | | Reimplemented the baud-rate algorithm from scratch to cope with GRCAN, GRCANFD and OC_CAN devices. Update #4323.
* bsps/xilinx_zynq: Add SPI driver to wafJan Sommer2021-03-104-0/+24
| | | | Updates #4320
* build: Fix broken linkSebastian Huber2021-03-091-1/+1
* spec/aarch64: Enable previously disabled testsAlex White2021-03-082-18/+2
| | | | | This enables several testsuites that were initially disabled during development.
* spec/aarch64: Rename ZynqMP QEMU BSPsKinsey Moore2021-03-053-3/+3
| | | | | | The current ZynqMP BSPs don't have _qemu in their name as do all other RTEMS BSPs that are specifically made to run on QEMU. This fixes the naming for those ZynqMP BSP variants for easier identification.
* spec: Move hypervisor start for use by AArch64Kinsey Moore2021-03-052-1/+1
| | | | | | AArch64 on hardware is often started at EL2 instead of EL1 from either u-boot or a first stage bootloader. This allows RTEMS to drop from EL2 execution to EL1 to operate as normal.
* spec/aarch64: Remove sp37 from intermittent testsAlex White2021-03-052-2/+0
* bsps/aarch64: Resolve usage of SUBALIGN()Kinsey Moore2021-03-052-2/+0
| | | | | | | | Remove usage of SUBALIGN() in aarch64 linkcmds which works around a difference in behavior on AArch64 platforms. This is no longer necessary since alignment is now enforced explicitly. Closes #4178.
* validation: Fix for 64-bit targetsSebastian Huber2021-03-042-6/+0
| | | | Closes #4179.
* bsps/beagle: Adding QEP driver support to BeagleBoneBlack BSPJames Fitzsimons2021-03-021-1/+4
* score: Fix _Stack_Extend_size()Sebastian Huber2021-03-011-0/+1
| | | | | Check for an integer overflow. Add a validation test for task create errors.
* build: Install <rtems/score/hash.h>Sebastian Huber2021-02-261-0/+1
| | | | Update #4267.
* libtest: Report target hashSebastian Huber2021-02-261-0/+1
| | | | Update #4267.
* bsps: Add default rtems_get_target_hash()Sebastian Huber2021-02-2688-0/+88
| | | | Update #4267.
* score: Add Hash HandlerSebastian Huber2021-02-261-0/+1
| | | | Update #4267.
* rtems: Add rtems_get_build_label()Sebastian Huber2021-02-253-0/+19
| | | | Update #4269.
* build: Sort source listsSebastian Huber2021-02-24126-785/+785
| | | | Use the Python sorted() function to sort the "source" lists.
* score: Remove _CORE_barrier_Do_flush()Sebastian Huber2021-02-241-1/+0
| | | | Call _Thread_queue_Flush_critical() directly.
* rtems: Simplify signal handlingSebastian Huber2021-02-201-1/+0
| | | | | | | Remove superfluous ASR_Information::signals_posted. Move code out of trivial inline functions. Update #4244.
* validation: Add signal manager testsSebastian Huber2021-02-202-0/+4
| | | | Update #4244.
* validation: Add Validation1 test suiteSebastian Huber2021-02-203-0/+22
| | | | Update #4244.
* Update motorola_power to irq-generic interrupt managementChris Johns2021-02-132-2/+3
| | | | | | | | | | | | | | - Add support to the BSP to enable irq-generic management - Update the powerpc shared irq code to support irq-generic. This is an opt in option for existing powerpc bsps. This change should be simpler now - Fix a number of issues in ISA IRQ controller handling by porting fixes from the i386 (PC) BSP Closes #4238 Closes #4239
* libcsupport: Add sbrk greedy support to consume all sbrk memoryChris Johns2021-02-101-0/+1
| | | | | | | | | - Move the heap sbrk code into a separate routnine. - Update heap and workspace greedy allocators to use the common sbrk greedy support. Closes #3982
* validation: Tests for barrier managerSebastian Huber2021-02-081-0/+4
* validation: Add tests for rtems_build_name()Sebastian Huber2021-02-081-0/+1
* score: Make FIFO thread queue ops publicSebastian Huber2021-02-061-0/+1
| | | | Update #4230.
* nios2: Allow ISR nesting in dispatch variantSebastian Huber2021-02-011-1/+0
| | | | | | Rename _Nios2_ISR_Dispatch_with_shadow_non_preemptive() in _Nios2_ISR_Dispatch_with_shadow_register_set(). Remove _Nios2_ISR_Dispatch_with_shadow_preemptive().
* bsps: Add missing DWARF 5 sectionsSebastian Huber2021-01-261-3/+5
| | | | Sort alphabetically.
* build: Add test excludesSebastian Huber2021-01-264-0/+6
* bsps: Support DWARF 5 sectionsSebastian Huber2021-01-251-8/+12
| | | | GCC 11 uses DWARF 5 by default.
* bsps/shared: Build fsl-edma only for certain BSPChristian Mauderer2021-01-223-5/+20
| | | | | Move the Freescale EDMA driver to it's own object and build it only for the BSP that is currently using it.
* bsps/imxrt: Add ioctl to LPSPI to get registersChristian Mauderer2021-01-211-0/+1
| | | | | | | | This allows an application to get the registers of the LPSPI. That is usefull for applications that want to use DMA for a very specialized and highly optimized communication. Update #4180
* bsps/shared: Adapt fsl-edma driver for imxrtChristian Mauderer2021-01-213-0/+23
| | | | | | | | | | Note: The changes have been done with portability in mind. The driver should (in theory) be able to replace the original one in the MPC BSPs too. For full compatibility an adaption layer and especially a test would be necessary. Because both are missing, don't integrate it into the MPC BSP now. Update #4180
* bsp/stm32h7: Split console configurationSebastian Huber2021-01-041-0/+10
| | | | | | | This allows applications to individually provide configuration structures. Update #4209.
* bsp/stm32h7: Split start configurationSebastian Huber2021-01-041-1/+5
* libtests/ofw01: Added a test for RTEMS OFWG S Niteesh Babu2020-12-272-0/+23
| | | | | This commit adds a basic test that tests all the implemented RTEMS OFW functions.
* bsps/shared/ofw: Implement RTEMS OFW interfaceG S Niteesh Babu2020-12-271-0/+5
| | | | | | | | | | | | | | RTEMS OFW is a FDT only implementation of the OpenFirmWare interface. This API is created to be compatible with FreeBSD OpenFirmWare interface. The main intention is to make porting of FreeBSD drivers to RTEMS easier. Most functions implemented have an direct one-one mapping with the original OFW API and some extra auxiliary functions were implemented to make working with device trees easier in RTEMS. Update #3784
* arm/fvp: New BSPSebastian Huber2020-12-2317-1/+395
| | | | | | | | This BSP supports the Arm Fixed Virtual Platform. Only the Cortex-R52 processor configuration is supported by the BSP. It should be easy to add support for other variants if needed. Update #4202.
* bsps: Use header file for GIC architecture supportSebastian Huber2020-12-2310-8/+2
| | | | | | This avoids a function call overhead in the interrupt dispatching. Update #4202.
* bsps/arm: Set VBAR in start.SSebastian Huber2020-12-231-1/+0
| | | | | | | | | | Set the VBAR to the vector table in the start section before bsp_start_hook_0() is called to earlier handle exceptions in RTEMS. Set the VBAR to the normal vector table in start.S for the main processor. Secondary processors set it in bsp_start_hook_0(). Update #4202.
