Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Add rtems_interrupt_entry_remove(). Split up irq-generic.c into several files.
In particular, place all functions which use dynamic memory into their own
file.
Add optional macros to let the BSP customize the vector installation after
installing the first entry and the vector removal before removing the last
entry:
* bsp_interrupt_vector_install()
* bsp_interrupt_vector_remove()
Use these new customization options in the m68k/genmcf548x BSP so re-use the
generic interrupt controller support.
Update #3269.
Add rtems_interrupt_raise_on() and rtems_interrupt_clear().
Add a default implementation which just returns RTEMS_UNSATISFIED for
valid parameters.
Update #3269.
Add rtems_interrupt_vector_disable().
Update #3269.
Update #3269.
Update #3269.
When compiling the lwIP port for the TMS570, there
were issues with the BSP. Headers are expected in a folder
named ti_herc which did not exist. This fixes the issue.
Furthermore, there were multiple warnings about define redefinitions.
This was fixed as well.
These patches were submitted a few months ago, but it was found out
that the default-by-family: [] were missing in the GPIO .yml lines.
This was fixed in this patch.
This patch accounts for different pins for the ETH peripheral
on STM32H7 devices. For example, the Nucleo H743ZI has slightly
different pins than other STM32H7 boards.
Update #4468.
This program contained an optional test case. It was enabled by the
RTEMS_COVERAGE define. The functions under test are not implemented by RTEMS.
- Optionally add support for 'default-by-family' to allow
option to be set by a family and so all related BSPs
Close #4468
Calling the memory FLASH and EXTRAM instead of FLEXSPI and SDRAM makes
it simpler to support other types of external RAM. This patch also
removes some of the calculations and improves names and documentation to
avoid pitfalls. It removes a unnecessary memory definition.
Update #4180
Update #4180
This reverts commit 10041a4cfc00d5f6876d3d6cfc30c23347b4cf42.
This type of configuration does not belong in RTEMS and is better
constrained to libbsd where the defines are actually being used.
Provide the options necessary to enable any combination of CGEM ethernet
interfaces in LibBSD. The default is still CGEM3, so this should
continue to operate as expected on typical Zynq Ultrascale+ MPSoC
development hardware.
Move _ISR_Handler() to a separate file since it is now only used if a handler
is installed by _CPU_ISR_install_raw_handler().
Statically initialize the traps for external interrupts to use the new
_SPARC_Interrupt_trap() which directly dispatches the interrupt handlers
installed by rtems_interrupt_handler_install() via the BSP-provided
_SPARC_Interrupt_dispatch().
Since the trap table is now fully statically initialized, there is no longer a
dependency on the Cache Manager in the default configuration.
Update #4458.
Statically initialize the trap table in start.S to jump to _SPARC_Bad_trap()
for all unexpected traps. This enables a proper RTEMS fatal error handling
right from the start. Do not rely on the stack and register settings which
caused an unexpected trap. Use the ISR stack of the processor to do the fatal
error handling. Save the full context which caused the trap. Fatal error
handler may use it for error logging.
Unify the _CPU_Exception_frame_print() implementations and move it to cpukit.
Update #4459.
Move _CPU_ISR_install_raw_handler() and _CPU_ISR_install_vector() to separate
files. The goal is to make their use optional.
Update #4458.
Update #4459.
The _ISR_Handler_initialization() does not touch the _ISR_Vector_table[]. Move
the definition of _ISR_Vector_table[] to a separate file.
Change license to BSD-2-Clause according to file history and re-licensing
agreement.
Update #3053.
Update #3269.
Make the initialization of the per-CPU data optional.
re-licensing agreement.
Update #3053.
Make sure that the linker sets work if placed in a library (this is how
they are used in RTEMS).
The a72 BSPs are identical to the a53 BSPs just changing a53 to a72.
Update #4202.
Also updated licenses.
Closes #4400
Updates #3899
Created futimens.c and utimensat.c to add support for the POSIX
methods futimens() and utimensat().
utime() and utimes() are considered obsolote by POSIX, but RTEMS
will continue to support them.
Closes #4396
Add the BSPs for running on the ZU3EG Ultrascale+ Zynq MPSoC and alter
the option defaults necessary for them to run properly using the
standard BOOT.BIN configured for PetaLinux that comes in the Out-of-Box
package.
Currently, the AArch64 BSPs have a hard time running on real hardware
without building the toolchain and the bsps with -mstrict-align in
multiple places. Configuring the MMU on these chips allows for unaligned
memory accesses for non-device memory which avoids requiring strict
alignment in the toolchain and in the BSPs themselves.
In writing this driver, it was found that the synchronous exception
handling code needed to be rewritten since it relied on clearing SCTLR_EL1 to
avoid thread stack misalignments in RTEMS_DEBUG mode. This is now
avoided by exactly preserving thread mode stack and flags and the new
implementation is compatible with the draft information provided on the
mailing list covering the Exception Management API.
The default available RAM on the A53 BSP is quite small at 8MB. This
bumps that to 128MB to avoid allocation failures in tmcontext01 caused
by large allocations on a cache size of 16MB reported by the system
registers in QEMU.
Break out system register definitions and accessors so that they're
usable by other parts of RTEMS.
telnetd01 test cannot be run without a network stack, so this test is being
moved to the rtems-net-legacy repository.
Move this diagnostic function to a separate file since it does not
provide a core function of the system.
Update #3053.
Move clock_nanosleep() to a separate file to avoid a dependency on errno
which pulls in the Newlib reentrancy support. This is an issue since
most parts which are pulled in cannot be garbage collected by the linker
due to the system initialization linker set.
